mtxpert
02-04-2003, 01:10 PM
I'm trying to find a writeup on the size of resistors and where to attach them on the OBDI PCM.
Let me know.
Mike
Let me know.
Mike
I need a how to on OBDI conversionmtxpert 02-04-2003, 01:10 PM I'm trying to find a writeup on the size of resistors and where to attach them on the OBDI PCM. Let me know. Mike madwolf 02-05-2003, 09:57 PM Hi Michael, you emailed me but I didn't have a chance to write back yet. Anyway, I can answer this question for you here. What are you converting from OBDII to OBDI? Impala or F-body? mtxpert 02-05-2003, 11:22 PM 96 Impala converting from OBDII to OBDI. I don't have to change tach drivers as I have converted to a Z28 cluster. Just need to verify that I need to short pins 21 and 22 together and then put a 2K resister to ground from those pins. Mike madwolf 02-05-2003, 11:26 PM Tach drivers???? That's a new one to me... But yes, you have the right info for converting an OBDII Impala to OBDI> mtxpert 02-06-2003, 09:16 AM Yeah the tach signal on a 96 Impala SS is a 4 cylinder tach pulse instead of an 8. If I just hook up a PCM directly to the factory tach it will read twice as fast. Mike drop top steve 02-06-2003, 10:53 AM The 94-95 knock sensor has a different impedance than the 96-97. So, if you convert your 96-97 car to a 94-95 computer you either need to replace the knock sensor(s) or solder the 2K resistor across the 94-95 knock sensor pins.... | ||
