Carb size for a 388 stroker
Old Feb 3, 2003 | 11:35 PM
RobZ's Avatar
Post Carb size for a 388 stroker
Need help on deciding to go with a 750 demon carb or 850 on my friends 388 stroker CHEVY SBC. Also what is the purpose of the Power Valve?
Old Feb 4, 2003 | 02:30 AM
pacesetter's Avatar
Depends on what you are going to be using it for... if you want a nice street machine go with a 750, if you want to drag it go with 850.
In simple terms, power valves are designed to open when the engine is under a load (such as when accelerating) and modify the economical air fuel mixture from approximately 14.6 to 1, down to a richer, power mixture of about 12.6 to 1. The needs of the engine, regardless of the number of carbs is pretty close to those numbers.
Old Feb 5, 2003 | 01:21 AM
RobZ's Avatar
Thumbs up
thanks for the help..My freind decided to go with the 850 and works great.
Old Feb 11, 2003 | 09:09 PM
Distortion28's Avatar
what is in this 388, i'm building a 388 also but i just have the short block completed.
Old Feb 11, 2003 | 09:46 PM
SSnthe10s's Avatar
Just put some EFI on it
One of those F.A.S.T boxs with a wide band O2
HectorM52
Jul 30, 2017 11:46 AM
bose
Jan 30, 2015 02:36 PM
Timberwolf
Oct 10, 2002 05:25 PM
