Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
trade your stock 3.42 or 3.23 rearend for a 3.73 with slp carrier/gears and cover
Old Feb 2, 2003 | 09:12 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Exclamation trade your stock 3.42 or 3.23 rearend for a 3.73 with slp carrier/gears and cover
any interest in trading your rearend for the one in my wifes car. it has new carrier bearing kit, and 3.73 gears, with aluminum cover. i am interested in a 3.23 rear end or 3.42 for a 94 z28. the rearend parts have a few thousand miles on it. to much gear for her automatic car. it is a daily driver type of vehicle, and i would prefer the gas mileage over a couple of extra tenths.
let me know if you are interested
thanks
taner
Old Feb 2, 2003 | 10:52 PM
triumph's Avatar
Hmmmmmmmmm
Old Feb 2, 2003 | 10:54 PM
Timberwolf's Avatar
Re: trade your stock 3.42 or 3.23 rearend for a 3.73 with slp carrier/gears and cover
thanks
taner
I'm in. I have 3.23 now... drop me a pm or email.
Old Feb 2, 2003 | 10:58 PM
IrocSS85's Avatar
I'll trade my 95 rear for yours if interested. its stock 3:42 just over 70K easy mi.s. no noise or anything wrong. but you gotta come here to do the swap in my gar. that I will heat. I also have an air comp. to make it even easier. I live about 40 min.s or so from the windsor bridge.
I cant do it till next week though cause i wont have enough free time before the car show on the 7,8,and 9.
email if interested.
chris
Old Feb 3, 2003 | 08:15 AM
taner's Avatar
car is in storage right now, I wanted to see if there was any interest. one key thing is I am looking for a rearend out of a car with lower mileage. all but axles are new in this rearend, so I am looking for something comparable, mileage wise. and the swap would have to occur at my place. i have all necessary equipment to accomplish this in a couple of hours. car will be out of storage in march sometime, most likely towards the end of march.
timberwolf, how many miles on your axle?
thanks for the interest.
Old Feb 3, 2003 | 09:44 AM
95 Z/28 LT1's Avatar
Super Moderator
Hey Taner, keep me in mind when you go to make the swap. I have a 3.42 rear in my '95 that has just over 70K on it. I just had the carrier/pinion bearings replaced by a GM dealer a couple of K ago too. Everything else was/is great (I Have receipts).
-Jacob
Old Feb 3, 2003 | 11:00 AM
Firehawk#69's Avatar
May be interested
I have a 2001 Firehawk w/ 3.23 rearend; car has less than 8K miles, since I work so often. Fluid was changed at 7,500 with synthetic royal purple, and the gears were in perfect shape. This sounds fairly interesting, since I was thinking of getting 3.73's eventually. Email me if you are still looking for someone to swap gears with.
Thanks,
Marco
Old Feb 3, 2003 | 01:25 PM
Timberwolf's Avatar
Sounds like you'd be better off with Marco's car than mine. I'll bow out.
Old Feb 3, 2003 | 01:46 PM
Super Moderator
Isn't the ABS on an LS1 a four channel setup, whereas the LT1 has a three channel? Or did it have something to do if the car has traction control or not? Just thinking out loud here...
Old Feb 3, 2003 | 04:14 PM
jshigman's Avatar
sounds interesying for a swap
ive got 48000 on my 95 z28 and the gears were just done about about 1500 miles ago from a chevy dealer3.23 ratio give me an email if interested at jshigman@comcast.net
Old Feb 3, 2003 | 07:30 PM
taner's Avatar
jacob
you are right, the abs is different.
thanks marco, my goal is to either swap out completely or i will just end up putting new gears in. also the gears are different in your 01 and my 94
well i know i have interested parties so, just got to wait for the warmer weather.
i will keep everyones email address that replied and get back to you as soon as i pull the car out of storage
boz.....
Old Feb 4, 2003 | 01:58 AM
Chris Ja's Avatar
Eternal Member
Smile
Taner I sent you a PM.
Old Feb 4, 2003 | 07:57 PM
taner's Avatar
chris,
u have too many pm's i tried to pm you back
Old Feb 4, 2003 | 08:38 PM
Chris Ja's Avatar
Eternal Member
Smile
Taner my PM box is emtpy. There is something else wrong.
Old Feb 5, 2003 | 12:02 AM
Brett H's Avatar
Hey Taner, I'd do it in a heart beat but my LS1 rearend won't fit
I was looking to go to a 3:73 gear myself but from your experience is it that bad for gas milage?
