Transmission problems (5th gear) experts help
Old Feb 1, 2003 | 03:29 PM
j9_ws6's Avatar
Here is the details of what happened. Okay, to save time you can follow this link
If you dont want to read, this is basically what happened:
This happened after I was locked out of all the gears going about 85+ and trying to shift from 4th to 5th. I was at moderate acceleration and it was not WOT. I have never smoked the clutch etc and it is a 02 m6. I was unable to shift into any gear (with the exception of 1-2. I pumped the pedal several times and still could not shift. I had to pull over, I thought all was well until I put it in 5th.
http://www.ls1.com/forums/showthread...4&goto=newpost
If my car is in 5th gear, the shifter will physically move on its own about 1/2 inch forward when I give it gas, and it will move back to its original position when I let off. This doesn't knock it out of gear or anything, but I need to know if this problem is serious or not. This happened after I was locked out of all the gears going about 85+ and trying to shift from 4th to 5th.
Jason
Old Feb 2, 2003 | 05:16 PM
j9_ws6's Avatar
ttt
F'n1996Z28SS
Aug 23, 2023 11:19 PM
edxiel
Jan 24, 2015 07:40 PM
Jul 4, 2005 05:00 PM
