Question about checking oil...
Old Jan 29, 2003 | 11:13 PM
ryan75's Avatar
Question Question about checking oil...
I never knew this but...if you check the engine oil while you're car is running, is it supposed to give a lower reading? Mine does. When I check it while the engine is off, it is normal. I guess the oil flows throughout the engine. I could have sworn I've checked my oil before while it was running (maybe in another car) and I don't remember ever knowing that. I thought I had an oil leak-the "LOW OIL" light stayed on after I cranked it yesterday, but I guess it got hung up. There was a little fresh oil on the passenger side valve cover, but I checked everywhere else and no leaks. It may be leaking very little at the hose on that valve cover (some sort of breather). What can I do to stop it?
Old Jan 29, 2003 | 11:18 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
you will definatly read less oil when the engine is running... i always wait at least 5 minutes after turning the car off if i want to check the oil... you gotta wait for it to all drain back down outa everything... but that shouldn't turn on your light...
Old Jan 30, 2003 | 05:26 AM
Patman's Avatar
No car out there will specify checking engine oil while the engine is running, since there is no way to get a reading properly when not all of the oil is in the pan.
You're thinking of an auto trans, which often needs to be checked with the engine running.
I found last weekend when I checked my oil level cold overnight, on an extremely cold night I might add, that it showed to be down a bit, which I knew wasn't true since I just added oil the week before. So I drove it 20 miles and then checked it about 15min after shutdown and the level was full. I think that in the winter this method is the best way to check oil.
ChrisFrez
Dec 28, 2014 02:25 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
