Chuckie 01-28-2003, 05:40 PM I have 144,000 miles on my 99 Camero. At around 100,000 miles I noticed that sometimes when I let off the gas and get back on it, the RPM's go higher than normal. Usually at 70 I'm doing about 2000 RPMs. Sometimes that goes up to around 23-2400 for a little while, then it will drop back to 2000. I change the fluid and filter every 20,000 miles. Any ideas?
V6 Punk 93 01-28-2003, 05:53 PM 144k on a 99 Camaro? Damn you must drive a lot. Are you sure it's not just kicking down into 3rd when you step on the gas again? (assuming it's an auto)
Chuckie 01-28-2003, 05:56 PM Yes I do drive a lot. It is an automatic. No it's not 3rd gear, because I want the tach and listen to the car and it's just kind of sluggish going back in. I haven't found any metal shving or anything on the Transmission pan magnet. The fluid always looks good, and there is no pattern to when it does this. I'n not sure what it is.
Sounds like the secondary shift active when higher rpms are happening,only when it disengages your feeling the lag when it(tranny) returns to normal.after being helped from engine tuning PCM
3rd&4th will split shift and raise the rpms temperarly. I would think this would happen more repeatedly with a motor thats losing power.
T.
97QuasarBlue3.8 01-29-2003, 02:18 AM Sounds like a slipping transmission to me. I once had a Lumina that was doing that at around 165k. No metal or burnt fluid in the pan--but every now and then the rpm's would kick up when going into the next gear.
You have me curious-- a '99 with 144k...so far what have you had to do to keep your car running well? Any major probs, and at what mileage?
Chuckie 01-29-2003, 08:48 AM Thanks for the replies. I haven't had any problems other than replacing the Alternator at around 120,000. It has been a good car, and gets good gas mileage. I have noticed a small drop in engine power, at least it seems like it has dropped a little. I put on new plug wires and plugs, but I haven't had a chance to get a really good tune up.
ImportKILLER 01-29-2003, 11:08 AM All I can say is...
:eek: :eek: :eek:
That is some major mileage on such a relatively young car. At least she's been good to you!
Can't really help you on the RPM problem other than it sounds like some sort of slipping. My car did that when I had to replace the valve body but I had other problems in addition though.
Good luck!
BradC 01-29-2003, 01:54 PM It's just kicking in and out of torque converter lockup in overdrivr. That's an easy one. :D
Guys he didnt say it was happening going into gear(that would be slippage) Its no prob. Chuck,normal funtion. Our cars have what I said,a secondary shift to avoid downshifting to a certain extent.
Brad interesting:confused: Feels more like an advance in timing or air/fuel,to me. My car does this in 3rd & 4th,aint nothin wrong wit the tranny.
That is a butt load o' miles there cuckie:D I got 55K.
BUT
55K repaired/replaced
1 K- member
1 oil pan
1 Y-pipe
Cat
1 Output shaft seal(tranny)
Rear end seal
4 sets brakes
Power steering pump
15 lug nuts($4.35 ea:eek: )
Battery
NEW this week!! Rack&pinion:cry:
The first 4 Damn rock in the road BAMM,Gotta love insurance ,No charge. Everything else is from most likely from racing.
T.
Chuckie 01-30-2003, 08:49 AM Thanks for all the help ya'll. I do travel a lot, and I have really enjoyed my car. I hope to buy another work car soon, and start fixing up my Camaro, just to be a weekend car. :cool:
chesee48 01-30-2003, 02:03 PM 144k? how many miles do u drive a day? did u have it brand new in 99?:confused:
Chuckie 01-30-2003, 02:11 PM I work for an electronics and computer distributor, so I travel a lot to our stores. I'm the Application Engineer. Actually I bought the car new in March of 2000.
BradC 01-30-2003, 02:51 PM You can test my theory by doing this: When your driving down the road and the car is in overdrive, while keeping your foot on the gas tap the brake. The the RPM rises then drops suddenly, then you will know it's disengaging then reengaging torque converter lockup.
