Suspension...what's first?
Old Jan 28, 2003 | 09:40 AM
95TA8280's Avatar
Title sums it up....I guess I have to go with some suspension...where should I start?
Old Jan 28, 2003 | 09:59 AM
Robbie_97z28's Avatar
I started with:
1. Subframe connectors - excellent handling mod
2. LCA
3. Relocation brackets
Getting
Panhard rod
Torq Arm
Old Jan 28, 2003 | 10:15 AM
Severous01's Avatar
sfc's are the best. id go next with the bilsteins or new shocks and springs. then lca's with brackets and a panhard rod. then a tac with lafety loop. then if you are serious, front lower and upper control arms.
Old Jan 28, 2003 | 10:27 AM
TedH's Avatar
What is your goal?
I started with wheels and tires. Unsprung weight reduction and something sticky.
Then I went for springs, shocks, and airbag.
I also removed the front sway bar and put in a six point welded roll bar.
Nothing else needed. 1.5 sixty foot times.
Old Jan 28, 2003 | 10:34 AM
chesee48's Avatar
i bought them all and am awaitng installs on most of them...
but this is what i did:
Kenny Brown DD SFC
MAC LCA's
MAC PHR
Bmr STB
BMR Relocation Brackets
QA-1 Hal Full Set-up Shocks/Springs
Old Jan 28, 2003 | 11:35 AM
95TA8280's Avatar
Originally posted by tnthub
What is your goal?
Goals: who knows....I'm still debating NAAAAAAAAAWS or not. I'm going with DRs in the back (ordering them soon) then, I dunno....I'd love to hit 11s, but I have a feeling I'll have to spray for it......
Old Jan 28, 2003 | 11:51 AM
pillagenburn's Avatar
well....
Here's what I did:
1. subframes (BMR)
2. strut tower brace (BMR)
3. front/rear anti-sway bars (BMR)
Next handling mod i'm going to go with is a better rag joint - i hate play in the steering wheel. After that I'm going to go with KYB shocks and BMR springs on all 4 corners .... then after that i'm going to get the biggest fawking wheels/tires my car can handle.....
Other things? traction mods i guess ... LCA's, panhard rod
p[eace
Old Jan 28, 2003 | 12:02 PM
Gripenfelter's Avatar
I would do LCAs and relocation brackets first.
Then subframe connectors.
Panhard rod if you Auto-X.
Old Jan 28, 2003 | 12:25 PM
LT1derful's Avatar
How makes a good Uper Control Arm? I'm going with Metco's LCAs; I got to see those at the Metco guy's garage and they look SOLID!!!!
Also, shocks/springs...which ones? What performance issues do Drag Springs address, and are there any weaknesses? If so, what's a good NON-LOWERING spring? Shocks?
DJ
Old Jan 28, 2003 | 12:28 PM
LT1derful's Avatar
Also, do relocation brackets come with most LCAs? Metco? If not, where to buy?
DJ
Old Jan 28, 2003 | 04:31 PM
AFAIK, LCA are sold without relocation brackets. Lotsa ppl sell these, you can get the weld in ones or the bolt in ones. I got the bolt on ones and will later weld it for added strength later...
