mehoffz24
01-27-2003, 10:58 AM
is it posible to run aftermarket pulleys when you instal a s/c since you have to put spacers behind the factory crank pulley. i was just curious because im really thinkinking about going with a p1sc pullied down to 6psi. thanks
David94TA
01-27-2003, 11:48 AM
You would have to have some kind of spacer to go on the supercharger to move the belt out, and I don't know that you would have that much room. Much easier just to take the underdrive pulleys off and go with stock. Besides that, the gains from the SC will be way beyond what little bit you give up with the underdrive pulleys.
95 Silver TA
01-27-2003, 12:55 PM
You can go to ATI to get a pulley size for your needs. They can go all the way down to 4.5 pounds (non intercooled) and Lonnie Pavtis always gives a good deal on ATI Products and Great Advice too. Here is his web-site...
www.westol.com/lpavtis
Hope that Helps,
mehoffz24
01-27-2003, 02:09 PM
thats what i was gonna do anyway was take the underdrive pulleys off, i now they didnt do much but ill have to sell em. figured that it would work best with stock anyways.
