Please Read and comment with chugging problem at 1500-2000 RPM
Old Jan 26, 2003 | 11:43 AM
1bad94z28's Avatar
After a month of checking things for the problem of chugging from 1500 to 2000 RPM, (I put in new plugs, new wires,checked egr, vaccum leaks, changed fuel filter, looked for induction leaks, checking connections, cleaning throttle body, checked air filter, checked PCV.) I was poking around in the engine bay and noticed that the weap hole was leaking and it could be leaking on the opti? It this possible and could it cause the miss described above?
I am thinking of new water pump and opti. Please help/comment thanks. Robert
Old Jan 26, 2003 | 09:32 PM
Rodrigues's Avatar
I had the same problem, the one thing which you havent checked could very well be the problem!! MAP SENSOR
NewsBot
Feb 6, 2015 05:00 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 21, 2015 06:10 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
