Hotcam: To keep, or to cc306??
Old Jan 26, 2003 | 06:14 AM
maserati82's Avatar
Here's the deal. I have (not yet installed), Hooker LT's, SLP CAI, LT4 hotcam kit, true duals, soon to be pcmforless programming
I have now decided to do head work also, and I don't need to pass emissions anymore (don't ask) so I was thinking of switching to cc306 instead.
Do you guys think it would be worth it? and what springs, rockers, retainers, rods, etc. do you recommend if so.
I know i am not going to want to switch to a bigger cam after this one is already installed, so I thought now would be a better time to go bigger. Does anyone wish they went with a bigger cam like the cc306 from the start??
Thanks a lot!!
-Chris
Old Jan 26, 2003 | 06:31 AM
WP's Avatar
WP
I had the hot cam,but got woop-assed by a Zo6!,our 1/4mile times were very close to eah other(my 12.6 vs his 12.5)but the mph(my 112vs 115mph) told me I needed more horsepower,its a never ending game!
Old Jan 26, 2003 | 07:27 AM
MEAN LT1's Avatar
I would go bigger as the majority of the people who get baby cams usually want to go bigger once they see there mph and et's. I would look at the 306 cam or some of the xe grinds as well. Just be forewarned that any big cam is goin to need more than a mail in tune, dont get me wrong, pcm4less is aswome but to get all the power out the cam it need to be dyno tuned. The springs I would recomend are any double coil valve spring as you will be pushing the 600 lift mark with 1.6rr.
Old Jan 26, 2003 | 09:52 AM
Cory_SS's Avatar
306
xxsaint69x ran a 12.7 @ 115 on stock heads.
My mind is made up, LT's and 306 all the way!
Old Jan 26, 2003 | 09:54 AM
chesee48's Avatar
no emmisions=cc306 with a doubt
Old Jan 26, 2003 | 09:55 AM
Joe94Z's Avatar
The CC306 is a big cam. If you are going to get heads. go ahead and get the cam. You would have wish you did if you did'nt.
Old Jan 26, 2003 | 10:08 AM
Cory_SS's Avatar
No doubt, Joe94z is right. You said you were going to do the heads, so get the 306!
I may run stock heads for a while but that’s b/c I'm on a tight budget for future plans and I know if I buy anything smaller I will regret it later on. So I'm going 306 and when I get my stroker assembly I'll do the heads then.
Think ahead, don’t sit there scratching your head after you bought a weenie hot cam. Go bigger, everyone else is!
Old Jan 26, 2003 | 10:18 AM
Rodrigues's Avatar
Also consider drivability... No one has even mentioned that yet.. I dont think you drive at 6600 rpm on the street too often...
Old Jan 26, 2003 | 10:29 AM
Smokn '94 Z's Avatar
Thumbs up
If you don't have emissions to worry about then I would go bigger. Especially if the car isn't a daily driver. Infact in the summer of '04 I might go bigger on my cam as well. That is when my next emission test is. But then again I am running real well with my little cam....
Old Jan 26, 2003 | 11:02 AM
Camaro37's Avatar
I wish I had gone with a larger cam first. I started out by installing a hotcam and was kinda disappointed, now I have a 306 and am very happy.
Old Jan 26, 2003 | 03:04 PM
maserati82's Avatar
Dude, if i can drive at 6600 RPM, i am going to drive at 6600 RPM. No but really, i don't care about daily drivability. I am a go big or go home kinda guy, and that is half the reason i feel like a pansy after getting the hotcam.
Haha, OK, if anyone wants a brand new hotcam, let me know. I will post in the For Sale section shortly. Thanks a lot for all your replies!
-Chris
Old Jan 26, 2003 | 03:17 PM
bad95z28's Avatar
i would say go bigger than the hotcam if emissions are no concern.
Old Jan 26, 2003 | 05:06 PM
z86roc28's Avatar
What would you guys use on a 383 lt1, with head work and 3.73:1 gears, if driveability and emissions were a problem?
Old Jan 26, 2003 | 05:29 PM
Camaro37's Avatar
I have a 383 w/ the 306 and 3.42 gears (M6) and it is great for a daily driver, no complaints. I don't know about emissions however.
Old Jan 26, 2003 | 05:30 PM
Johnnynsac's Avatar
Re: Hotcam: To keep, or to cc306??
Thanks a lot!!
-Chris
So, what are you going to do about emissions since you live in cali. I would like to know your thoughts about this?
My smog time is coming up so I'll probably install the 306 after I smog it. Then I'll have two years of driving and two years of trying to make it pass.
