front grill removal
Old Jan 24, 2003 | 04:27 PM
stevenscamaross's Avatar
front grill removal
I've been outside for the past 1/2 an hour or so getting frustradted on how to remove the stock front grill, any pointers appreciated... Thanks
Old Jan 24, 2003 | 04:29 PM
PhantomTA's Avatar
Moderator
just pull it off...
Old Jan 24, 2003 | 04:40 PM
jd13's Avatar
I actually had to cut some of the plastic clips off because the harder I pulled, the more it stressed the body underneath.
Old Jan 24, 2003 | 04:50 PM
99blackSS's Avatar
I just ripped mine off, no ever said anything about putting it back on. I ended up using screws to put it back on.
Old Jan 24, 2003 | 06:53 PM
Z28LS1Pewter's Avatar
It justs pulls right off and the clips will break or unclip, but I hope you know you can't reuse or at least I can't reuse mine.
Old Jan 24, 2003 | 07:07 PM
JaysZ's Avatar
There are 3 clips that run along the bottom of the grill that can be popped off. You have to reach up from underneath the car and behind the grill. Just remove the 4 pushpins that run underneath the bottom of the front fascia. I had to jack the front end up a little ways to fit my body under there. If you reach in and feel around for the back of the grill, you will feel the metal retainer clips that run along the bottom. Have someone pull on the grill from the front while you manipulate the clips (after you pop the grill out at both far sides). They come out pretty easily. Unfortunately, there are also 3 plastic studs that run across the top. These have to be ripped off (these are backed with metal retainer nuts) unless you want to further dismantle the front of your car. Just hold the fascia in place at each stud point while someone pulls (slowly) until each gives. You won't hurt anything.
Old Jan 25, 2003 | 01:26 AM
stik6shift98's Avatar
rip that biatch right off......
i had taken the front bumper off to do mine
Old Jan 25, 2003 | 12:31 PM
SpecForceZ28's Avatar
just rip it off, when i tried to get my friends off, it looked like the front bumper was about to come off, but just pull really hard a couple of times.
Old Jan 26, 2003 | 12:28 AM
rncotton's Avatar
exactly what JaysZ said. When I had the '01 Z28, I removed that black insert so I could cut the foam from behind the holes and help get some air up into the engine bay.
Unhook the bumper cover from underneath, reach under and work the metal clips from the bottom and then work on the top, pulling a little at a time and going from one side to the other.
It takes about 15 minutes of patience, but you can get that sucker off intact and still be able to put it back on.
Since I did not retain the upper clips (didn't remove the entire bumper cover) I hit each of the posts on the top of the insert with some black silicone and let it set, which made the posts bigger. Then I trimmed them down to get a real good friction fit on the holes and replaced the metal retainers only on the bottom.
When I totalled out that car ... the front bumper insert was still in place.
PROJECT X
Apr 17, 2015 12:13 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Dec 17, 2014 11:00 AM
Dec 4, 2014 11:56 AM
