94 Cat Back v 96 Cat back
Old Jan 22, 2003 | 10:57 PM
Paul94Z28's Avatar
Hey Board,
I have a 94 Z28. I installed edelbrock headers and y-pipe with a high flow cat that runs through the factory I-pipe with a flowmaster muffler.
I am planning on ripping out the stock cat-back and high flow cat and replacing it with a SLP 2OTL from a 96 SS. Can I just have the muffler shop weld on some extra 3" stainless steel to bridge the gap? Any other mods I will have to make to pull this off?
Help appreciated.
Thanks.
Old Jan 23, 2003 | 08:12 AM
EviLBoX's Avatar
That's all it should take, just a couple feet of 3" pipe welded in.
Old Jan 23, 2003 | 08:46 AM
teke184's Avatar
that's all you should need, depending on what the shop quotes you for price you may be able to save some $$ by lookin into the S pipe that either tbyrne or thunder racing sells...just a thouht..
Old Jan 31, 2003 | 06:22 AM
Paul94Z28's Avatar
Cat-back
Hey Teke-
I thought you only needed the s-pipe if you were using a 95-97 dual cat setup to bring it over to the 93-95 cat location.
At any rate, I am goin to get it welded up as soon as the roads are dry.
Thanks for your opinions.
Old Feb 21, 2003 | 09:40 PM
Paul94Z28's Avatar
It is on!
I had it installed on the car. I need an s-pipe, so that is the only part still 2.75. The cat and cat-back are 3" now. I was disappointed at first with the sound at idle - really tame compared to the flowmaster. When you get on it, this thing screams - noticeable SOTP power gain. I can't wait to dyno it again!
Thanks for the help fellas!
Here is a pic:
http://mywebpages.comcast.net/plsteepe12/2otl.jpg
Later,
Old Feb 23, 2003 | 08:48 AM
Greasepunk's Avatar
Re: 94 Cat Back v 96 Cat back
Originally posted by Paul94Z28
Hey Board,
Help appreciated.
Thanks.
I'm thinking about getting some edelbrock headers, did you notice a SOTP gain? And do you happen to have the P/N layin around still? Any info on these headers would be greatly appreciated! TIA!
--Tim
Old Feb 23, 2003 | 08:46 PM
Paul94Z28's Avatar
Edelbrock Headers
Hey Greasepunk-
I did notice a good gain with the headers even though I did it backwards. I just replaced my catback now and should have done that before the headers. I bought them used from this board and had them jet hot coated so they look new. I am very happy with them and do hear everyone saying go with long tubes. I did not want to worry about clearance and these headers I could actually afford on my rather constrained budget. Plug access is ok and no burned wires yet - I most likely will replace wires at 100K with the factory set so no buning will take place.
My car dynoed 264/299 on a dynojet with the fipk, headers, 1.6 roller rockers and flowmaster muffler(no catback so pretty choked). I am expecting to get it dynoed again this summer after my hotcam goes in.
Here is my car page if you want to see how they look installed:
http://mywebpages.comcast.net/plsteepe12/camaro.htm
Good Luck,
armedtrigger
Feb 24, 2015 08:30 PM
alex5366
Feb 17, 2015 09:07 AM
rockync7
Jan 1, 2015 05:10 AM
Dec 1, 2014 08:08 AM
Carson96Z28
Aug 28, 2002 05:23 PM
