Gears which ones
Old Jan 22, 2003 | 09:42 PM
Sterlingsxe's Avatar
Gears which ones
Guys im getting 3.73 for my A4 z28. Im wondering where the best ones are and the cheapest ones thank you very much
Old Jan 22, 2003 | 09:50 PM
LimitedEd1LE's Avatar
The Richmond gears are probably one of the best gears made. The splines are not that round at all and are almost straight. Although they can be a little whiny, that are very strong and give good bite. GM Motive gears are also good and I think a little cheaper. I know the Richmond gears are like around $190 with the instalation kit. Not sure on the GM Motive ones though. Hope this helps.
Old Jan 22, 2003 | 09:51 PM
you know a web site or anything and yes thank you this helps alot
Old Jan 22, 2003 | 09:53 PM
Derrick Redd's Avatar
I like the factory GM gears myself. They are known to be quiet and not to whine. If setup properly of course.
Old Jan 22, 2003 | 09:55 PM
again any idea where i can get them. And how much top end will i loose with these and how can i gain it back?
Old Jan 23, 2003 | 11:39 AM
BUBBA's Avatar
GM/OEM Randy'd Ring and Pinion (Seattle)
Drive Train Specialties (Michigan)
Old Jan 23, 2003 | 11:46 AM
belac350's Avatar
goto www.gearsrus.com I got Motive Performance from there, no problems
Old Jan 23, 2003 | 02:16 PM
guyww's Avatar
Has anyone done this?
Hello,
Although this is my first post, I have been reading your board now for about 6 month. I own a 1997 Trans Am, M6, so I usually hang out at the Formula Forums, but read as many LT1 related boards as I can.
Anyway, I have thought about doing the ring and pinion gear change, and installing the bearing kit like one from Ratech for quite a long time as I'm getting a lot of noise from the rear end.
I have talked to many mechanics who want to charge upwards of a grand to do this. They have warned me against doing this myself, and none of the guys at the Formula Forums have done this themselves.
Has anyone done the gear change themselves? If so, what would you rate the difficulty level? I'm in the military and have access to an auto hobby shop with lifts and tools and such. Does anyone know of any good instructions out there on the web? Do the gears and install kit come with instructions?
Thanks for any help you can give me.
Cheers
William
Old Jan 23, 2003 | 02:59 PM
BUBBA's Avatar
I had my mech. do the gears using the RATECH solid pinion spacer and shims.
He charged me 4.9 hours labor plus 14.00 for gear oil, etc.
Total: $360.00 for the install.
Paid $267.00 for GM/OEM Ring and Pinion
$79.00 for bearing kit
$15.00 for Ratech kit.
$225.00 to send my pcm to PCMFORLESS for programming for gears and other stuff, including Lt4 Knock Module.
$7.00 for GM gear additive.
So almost a grand for the whole deal.
I do recommend that you go with GM/OEM gears rather than after market stuff like Motive, Strange, Richmond (only because the OEM stuff is just like the gears you're taking out and they are quieter than most others). JMHO.
Old Jan 23, 2003 | 04:00 PM
97FormulaWS-6's Avatar
Well.... Seeing I've got a shot Pinion bearing I'm replacing the gears in my rear as well.
I personally want to make sure the rearend can hold up to any abuse I can throw at it, within reason without upgrading to a 12bolt, thus I'm using the TA cover as well...
After shoping and comparing prives EVERYWHERE.... the best deal is from Thunder Racing.. their complete rear-end deal with every part needed for $459. You're NOT going to find a better deal for what you get in the kit.
I'm going with GM Motive 4.10s from Thunder Racing with the TA cover and stud kit.
Old Jan 23, 2003 | 04:10 PM
chesee48's Avatar
ive heard good things bout motive, but u cant go wrong with GM IMO...Thats what im using currently
Old Jan 23, 2003 | 04:13 PM
Why don't people get it.... GM=Motive
that's why they're sold as GM/Motive
Old Jan 23, 2003 | 04:28 PM
BUBBA's Avatar
Are you absolutely sure about that? Motive may make the GM aftermarket gears but are the factory installed gears made by motive? Just curijous.
And...I just said that my 4.10s cost $367.00 for the Ring and Pinion, the bearing kit and the Ratech shim kit. Including shipping.
Gears are Genuine GMs.
$459.00 - $367.00 = $92.00. Fuzzy Math?
Plus, I've even seen them less expensive.
Old Jan 23, 2003 | 04:55 PM
BUBBA's Avatar
OEM=Original Equipment. Motive is not original equipment. Motive is after market made to OEM specs. Motive usually less expensive, run a little warmer, a tad noisier, and probably don't fit to a tee like an OEM gear will.
Not saying Motive isn't a good gear whether its made in Korea or Mexico or N.J. Just saying that it is not Original Equipment.JMHO
You can get a set of 3.73s for around $600.00 from a GM dealer or get them other places for less than $400.00 including Timken Bearing kit with National seals, a RATECH kit and shipping.
Just trying to get you guys a fair price.
Old Jan 23, 2003 | 05:16 PM
96LT1Fan's Avatar
Anybody ever had a dealer install OEM 3.73 or 4.10 gears? Prices? I'm sure it's not cheap....
