Bleeder screw is leaking,Got the brake lines and all the air out but now what please
BLACK Z !
01-22-2003, 07:58 PM
The bleeder screw is leaking at the thread on the right side caliper, what can I do to fix this? It is only a little bit but I don't need it to leak at all, as far as I know the bleeder screw is tight,I got all the air out already and I don't want to do it again. what ever you guys tell me to do will I need to bleed the whole system again? thanks
99huggerorangeZ
01-22-2003, 08:33 PM
i would suggest removing the screw and wraping the treads with teflon tape then screw it in again it should stop it from leaking
that is what i wrap my fuel line threads that go into my carb to make sure that i have a tight seal even though it doesnt leak
I EAT T/A
01-23-2003, 01:06 AM
Did you strip it??
If so, you'd either tap it or buy a new caliper. Otherwise try the teflon tape trick, that should work.
