strange sound
Old Jan 21, 2003 | 06:55 PM
steelerfan's Avatar
strange sound
Has anyone else encountered a kind of rubbing sound when going over a dip in the road or on uneven road surfaces?I only hear it on cold winter days.I'm guessing it's the soft lower body panels flexing but because of the cold they're stiff and instead of flexing the way they do in warm weather they rub instead.Does anyone else have this problem?Does anyone know what it is?Does anyone know how to fix it??
Old Jan 22, 2003 | 12:29 PM
NEWBIE T/A's Avatar
Question Shot in the dark, but ...
Could it be the suspension bushings are dry ??
I have been told that is the cause of my squeaking in cold weather - sounds like birds chirping inside the car.
Too lazy to get underneath it & silicone spray it, though.
Good Luck !
Britt
Old Jan 22, 2003 | 04:11 PM
steelerfan's Avatar
There's a thought!I'll have to get under there and look around and spray anything that looks like it could make noise.Thanks
Old Jan 22, 2003 | 05:39 PM
stik6shift98's Avatar
ya spraying sounds good.....or is in your car bottoming out
Old Jan 23, 2003 | 04:28 PM
steelerfan's Avatar
Defintely not bottoming out.Sound seems to be coming from both rear quarter panel areas,but the way sound transmits through a car there's no way to tell if the sound is originating from there.
Old Jan 23, 2003 | 04:36 PM
XKnightRider's Avatar
Most likely it's your LCA bushings, lube them they should quiet down. I got some Hotchkis one's now and they have grease fittings...makes things easy. Reminds me I need to do them soon, they are starting to bark a bit Like when I pull into a drive way or other uneven surface.
Old Jan 24, 2003 | 04:21 PM
steelerfan's Avatar
Thanks.I'll start with the LCA bushings first and see if that does the trick.I was gonna go under the car and lube every bushing in sight but I think I'll be better off in the long run doing one thing at a time till I figure out where the sound is coming from so next time I'll know right where to go if the noise comes back.Again,thanks.
Nayr
Mar 3, 2023 08:34 PM
rvonsternberg
Sep 14, 2015 11:58 AM
95craz28
11
Sep 12, 2015 07:47 AM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
