Cap question
Old Jan 21, 2003 | 04:06 PM
Gripenfelter's Avatar
Cap question
I picked up a 1 farad EFX Cap a while back and in the wiring instructions it also gives you an alternate wiring diagram for people that want to use a cap as a backup battery of sorts?
Has anyone tried this?
Is it worth getting another cap to work as a back up battery as well as using one cap for your stereo?
I paid $140cdn ( $87 u.s.)
Old Jan 21, 2003 | 06:21 PM
x7x7's Avatar
what do you want to use it as a backup for? I wouldn't use a 1 farad cap for anything more than supplying power to a current hungry amp.
Old Jan 21, 2003 | 08:13 PM
okies.
Old Jan 21, 2003 | 11:05 PM
robert_T's Avatar
backup battery?
dude, If you battery goes out, your cap wont last more that 10seconds without recieving power
Old Jan 22, 2003 | 12:58 AM
Skull Leader's Avatar
Lightbulb
Howbout a Batcap? It's claimed to be a battery and cap at the same time. You can get em for about $140 on Ebay.
Old Jan 22, 2003 | 10:01 AM
I don't need a backup battery guys.
I was just wondering WHY would they give you a wiring diagram to use the cap as a backup battery??
Old Jan 22, 2003 | 03:30 PM
ibanez6rg's Avatar
I'm not sure. A cap is there just to give power to the amp at a faster rate. It juices up and then unloads, way faster than a battery can.
Old Jan 24, 2003 | 10:41 AM
eyeoutthere's Avatar
It is not meant to be a backup battery. They probably put it there if someone wanted to use a cap to steady the voltage of their entire car instead of just their amps. (For instance, to lighten the load of a accessory coming on that has a high initial current draw like a fan.) But that is just a guess.
Theoretically, the cap should have the same effect on all components of the car regardless of placement. But it doesn’t quite work that way.
Old Jan 24, 2003 | 12:36 PM
Ok thanx that makes more sense.
calaban
May 18, 2020 06:43 PM
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
