94' Camaro 383 377hp 398 tq Low reserve
Hey guys I just posted my 94' Camaro on ebay with a low reserve. Most of the car was rebuilt 105 miles ago. Here is the ebay link.
http://cgi.ebay.com/ebaymotors/Chevr...#ht_560wt_1167
Here is a mod list of the car:
94’ Camaro parts list
enigine:
• JE Forged Pistons with the ringland moved down for nitrous $449.99
• Forged Eagle Connecting Rods $638
• Forged Lunati Crank Shaft
• Intake was ported and polished by GTP $295
• GTP Stage Two Heads $1999 http://gtp-racing.com/
• GTP 6 Billet Cam $395 http://gtp-racing.com/
• ATI Super damper $399.99
• Optima red top battery $169.99
• Hypertech 160 degree thermostat
• Arp head studs $119.99
• Re ceramic coated headers $225
• Walbro in tank 255 Liters Per Hour $129.97
• Arizona Speed and Marine 54 mm Throttle Body $450
• 30# SVO injectors $219.88
• Crane roller lifters $209
• GM extreme duty timing set $299.99
• Cloytes oversized crank sprocket $40
• TPIS long tube headers $700
Machine Work:
• 4 bolt splayed caps
• boil, and glass bead the block. Bore and hone block w/ torque plates, align bore for 4 bolt caps, surface block, clearance block for stroker kit, machine pistons for clearance on pin side, balance rotating assembly, assemble crankshaft and piston assembly. $2500
Computer:
• New Engine control module $180.00
Ignition:
MSD coil and 6AL box
Steering:
• New ARI rack and pinion steering $190.95
• New Tie Rod ends $81.02
• New wheel bearings $305.95
Suspension:
• BMR K-Member black $439.95 http://www.bmrfabrication.com/F-bodyChassis.htm
• BMR Upper and Lower a-arms $579.99 http://www.bmrfabrication.com/F-bodySuspension.htm
• Spohn Torque Arm with front and rear drive shaft loops black $484.87 http://www.spohn.net/shop/1993-1997-...ersY-Pipe.html
• LG G2 weld in subframe connectors $199.00
• LS1 front spindles, brake calipers, and caliper mounts
• Ground control front coil over koni (single adjustable) 750# springs, koni (single adjustable) shock with 250# springs on an adjustable perch in the rear. $986.90
• powdercoating for spindles, swaybar, and capiler brackets $250
• Spohn adjustable lower control arms in the rear $209 http://www.spohn.net/shop/1993-1997-...t-Spacers.html
• Spohn adjustable panhard bar $139 http://www.spohn.net/shop/1993-1997-...-Rod-Ends.html
Brakes:
• Baer drilled and slotted 2 piece Eradispeed Plus rotors (98’-02’ due to the spindle, caliper, and caliper mount swap) in the front $467 http://www.thunderracing.com/catalog...sid=52&pcid=21
Drivetrain:
• McLeod Street Twin dual disc Clutch with steel flywheel $715.00 http://www.mcleodind.com/product_guide.html
• 1LE Aliminum drive shaft
• prothane motor mounts
Seats:
• Corbeau Carrera black seats (qty 2) $745.00
Roll Bar:
• Wolfe Race Craft 4130 cromoly 6 point black powdercoat bar $942.84 http://www.wolferacecraft.com/detail.aspx?ID=289
Over $15,000 in receipts not including misc parts and the car itself
99% of everything here has 105 miles on it.
enigine:
Machine Work:
Computer:
Ignition:
Steering:
Suspension:
Brakes:
Drivetrain:
Seats:
Roll Bar:
That was a nice car
