All Mustang models will get upgraded brakes...
Old Oct 11, 2009 | 10:32 AM
Z284ever's Avatar
According to the rumor mill, the V6 will get the current Mustang GT brakes, the GT will get the current 14+ inch, 4 piston Brembos from the GT500, and the GT500 gets an new 15 inch Brembo system.
All this coincides with Mustang's all new powertrain line-up, which should be revealed in afew weeks at the LA show.
Old Oct 11, 2009 | 10:36 AM
The Untouchable's Avatar
lucky rustang owners
Old Oct 11, 2009 | 03:04 PM
black02's Avatar
Bigger brakes are heavier....
Old Oct 11, 2009 | 03:22 PM
91_z28_4me's Avatar
And they stop the car better...
Old Oct 11, 2009 | 03:29 PM
DvBoard's Avatar
The less the car weighs the less braking the car NEEDS. It's a trade off.
Old Oct 11, 2009 | 04:06 PM
91_z28_4me's Avatar
Do you honestly believe Ford would put on larger brakes that weigh so much they will increase braking distance?
Old Oct 11, 2009 | 04:11 PM
Sleepy_Z's Avatar
For the weight difference it's still worth it.
Old Oct 11, 2009 | 04:43 PM
Z284ever's Avatar
Makes sense with the power increases.
As far as weight, the V6 and GT500 are expected to lose weight.
Old Oct 11, 2009 | 07:09 PM
black02's Avatar
I'll wait for the actual data.
Old Oct 11, 2009 | 07:11 PM
black02's Avatar
Yes. It just goes to show that it's often worthwhile to upgrade components even though weight goes up.
Old Oct 11, 2009 | 07:25 PM
96_Camaro_B4C's Avatar
Not necessarily, though they are (or should be) more resistant to fade.
If the current smaller brakes can already apply enough braking force to induce an ABS event in the dry, then the stopping distance is traction limited, not brakeforce limited. Tires are critical.
The LT1 F-cars put out some pretty spectacular braking numbers (for the time) with their dinky 11" front rotors when they debuted. But I don't think they would hold up to repeated hot laps very well...
Old Oct 11, 2009 | 07:57 PM
Z28x's Avatar
V6 is going from 200HP to GT levels of over 300HP so I guess it is appropriate to get the better '10 GT brakes.
Old Oct 11, 2009 | 08:02 PM
V8 Slayer's Avatar
So pick the crappy stock ones... Ill take the brembos...
Old Oct 11, 2009 | 08:03 PM
DvBoard's Avatar
I'm saying once you get to the point where you can lock up the wheels, bigger brakes don't do you any good. It's all traction at that point.
Old Oct 11, 2009 | 08:15 PM
SSbaby's Avatar
Do the bigger brakes necessarily also mean bigger wheels?
Oh dear, the Camaro weighs too much syndrome all over again!
