BlowBye
01-20-2003, 10:56 PM
Im running V belts not serpentine. Beside converting to serpentine any way that the paxton kit like i said made for 88' up TPI fit my 87' TPI? BTW the only belts im running is waterpump,powersteering,crank and alternator.
wasted420
01-20-2003, 11:27 PM
the 87 uses a MAS and i believe the 88 does not
BlowBye
01-20-2003, 11:39 PM
What is a MAS? Are your referring to MAF as in Mass Air Flow sensor? Cause its produced from 85-89
wasted420
01-20-2003, 11:42 PM
yepp i screwed up ..my bad ..i thought 88 changed ..yeah i was talking about MAF
aziroc
01-21-2003, 01:40 AM
88's had speed denisty. not MAF.
Chris Ja
01-21-2003, 02:08 AM
You would have to change from a V belt system to serp belt system.
IROC5.7TPI
01-21-2003, 08:06 AM
Sorry but you're wrong. 88's had MAF.
And all you have to change to use the blower is the belt setup.
Osmosis
01-21-2003, 10:28 AM
I think it will bolt up, however, you may have to get a special addapter for the MAF. The MAF cars are for 89 and below. 90 and up are speed density. Since it is a 87, it has a different blet system and that may be a problem, but not huge. I'm sure you can omit or even change some things around eailsy.
