Suspension Setup Questions
Old Oct 6, 2009 | 03:00 PM
Need4Camaro's Avatar
I know very little about suspension systems. Long story short, I am going to put an Iron Block LQ4 in the firebird so it's going to be slightly heavier than the LS1. I want to know a good front and rear suspension setup that will allow me to both hook up and handle. I don't want to lower the car more than half an inch, if even that however.
What kind of Front / Rear Springs should I go for? Are the stock LS1 springs any decent or should I replace them?
Front/Rear Springs with KYB AGX Shocks?
What about the front/rear sway bars and LCA's?
Old Oct 9, 2009 | 08:15 AM
teke184's Avatar
stock springs on upgraded shocks.
Koni SA would be ideal, but the AGX might be a good budget choice.
since the front will be lower with the added weight, i would pull the rear spring isolator to level it out.
sway bars made a HUGE improvement in how my car handled. much flatter in the curves.
Old Oct 9, 2009 | 11:01 AM
9T8W66's Avatar
Ae you starting out with V6 Springs or V8 Springs ?
Because the V6 front springs are softer the rears are the same V8 or V6.
Old Oct 9, 2009 | 01:21 PM
It's a V6. Yea, I know the front setup on the V6 is weaker than the LS1 setup.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Hurin
Dec 13, 2014 07:38 PM
