GM to stop Duramax diesel output for 4˝ months
Old Sep 29, 2009 | 04:16 PM
95redLT1's Avatar
DETROIT -- A 4˝-month pause in production of the Duramax diesel engine threatens supplies of profitable Chevrolet Silverado and GMC Sierra diesel pickups.
Not only is GM's pickup inventory lean, but analysts also predict that sales will start to recover while the Duramax engine plant is down.
GM is scheduled to stop building the current version of the Duramax in mid-December. Production of a re-engineered 2010 Duramax is scheduled to restart in late April.
During the pause, GM will retool the Moraine, Ohio, plant where the engine is built, and GM engineers will tune the 6.6-liter turbocharged diesel V-8 to meet tough new emissions rules that take effect Jan. 1.
The revised engine will add a system to inject urea into the exhaust periodically. The chemical reduces oxides of nitrogen or NOx. The pickups will add low-fluid alerts to prompt drivers to refill the urea tank.
Some dealers worry they may run out of diesel-powered versions of the Chevrolet Silverado and GMC Sierra because of the gap in production.
“We got a notice yesterday that starting immediately, we can no longer order the Duramax regular cab,” said Scott Brasher, general manager of Brasher Motor Co. in Weimar, Texas, near Houston.
Brasher still can order extended-cab diesels, and he expects to place his last order for them next month. He also has been buying diesel trucks from other dealers to pad his inventory.
GM Powertrain spokesman Tom Read said GM plans to build inventory of Duramax engines this fall. The Duramax for the 2009 model year can't be built after Dec. 31, but engines that already have been built can be installed in vehicles after that time.
Ford Motor Co. is also launching a new diesel truck engine next year. But spokesman Anne Marie Gattari said Ford dealers will not run out of diesel-powered Super Duty trucks.
Gattari said Ford will stop production of the 2010 model year F-series Super Duty in December and then switch to a new engine and revamped truck in the first quarter. Ford's re-engineered diesel pickup also uses urea injection to reduce harmful emissions.
As of Sept. 1, GM had a 60-day supply of Silverados and a 71-day supply of Sierras. GM won't say how many of those are diesel-powered.
“We've been communicating with dealers, and we feel very comfortable we can meet their needs,” said GMC spokeswoman Dayna Hart.
Chevrolet spokesman Brian Goebel said GM will build up diesel pickup inventory for the rest of the year. The company also uses the Duramax in chassis-cab models and large vans.
Brasher said many more buyers are taking a second look at the gasoline-powered version of the heavy-duty Silverado because of the high cost of the diesel engine and the higher cost of diesel fuel.
“We're having much better luck with the gasoline engine,” he said. “Right now sales are running 60 percent diesel, 40 percent gas. But three years ago, it was 90 percent diesel and 10 percent gas.”
GM is spending $70 million on the Duramax plant.
http://www.autonews.com/article/2009...909299986/1262
Old Sep 30, 2009 | 07:57 AM
My Red 93Z-28's Avatar
90% Diesel and 10% Gas? I have a hard time buying that, especially three years ago. I know companies are banking diesel engines before 2010 so they can wait a little bit longer before they have to put in the new diesels that meet 2010 emissions.
Old Sep 30, 2009 | 12:38 PM
muckz's Avatar
I assume that the dealer refills urea? How often does this have to happen, every oil change, or at sooner intervals?
Old Sep 30, 2009 | 02:12 PM
Geoff Chadwick's Avatar
The numbers vary based on engine and such, but its somewhere between 2gal and 5gal of Urea per 100gal of Diesel. The numbers may be more in the 2-3 range for the new Duramax though. Either way, you're refilling Urea every handful of fuel fills.
Old Sep 30, 2009 | 10:32 PM
formula79's Avatar
Isn't their a relation between urine and urea? I would be pissed having to put **** in my truck.
Old Oct 1, 2009 | 06:45 AM
Yes.
From wiki:
Urea or carbamide is an organic compound with the chemical formula (NH2)2CO. The molecule has two amine (-NH2) residues joined by a carbonyl (-CO-) functional group.
Urea plays an important role in the metabolism of nitrogen-containing compounds by animals, and is the main nitrogen-containing substance in the urine of mammals. Being solid, colourless, odorless, neither acidic nor basic, highly soluble in water, and relatively non-toxic, urea is widely used in fertilizers as a convenient source of nitrogen. Urea is also an important feedstock for the chemical industry. The synthesis of this organic compound by Friedrich Wöhler 1828 from an inorganic precursor was an important milestone in the development of chemistry.
http://en.wikipedia.org/wiki/Urea
Old Oct 1, 2009 | 10:18 PM
HAZ-Matt's Avatar
Ha it goes something like this:
Old Oct 1, 2009 | 10:21 PM
graham's Avatar
So uh how do you get the little "1/2" instead of the regular size text? lol
Old Oct 1, 2009 | 10:29 PM
95redLT1's Avatar
ALT 0189 on ur number pad
http://usefulshortcuts.com/alt-codes...-alt-codes.php
Old Oct 1, 2009 | 11:04 PM
formula79's Avatar
So...who's job is it to harvest the "Urea"...or will the new Durmax trucks have a play for you to "fill" the urea, yourself. Who says diesel is not green?
Old Oct 2, 2009 | 01:13 AM
graham's Avatar
Originally Posted by 95redLT1
Awesome! lol ≡)
Old Oct 2, 2009 | 06:51 AM
Diesel was pretty green even before the new 2010 emission standards. I'm not sure how the distribution of urea will be setup. This seems to be the way that several diesel companies are going. The only other way I know of is Navistar's Advanced EGR setup that does not use urea.
AdsoYo
May 2, 2018 03:21 AM
May 1, 2015 01:14 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
Alex Barnes
Jan 24, 2015 10:21 PM
chevysam
Jan 16, 2015 07:45 PM
