AZ2ENVY
09-28-2009, 04:54 PM
Does anyone know if ill have any issues running 18x10.5 56mm offset wheel on the fronts ? If not what size tire should I run ? Thanks in advance !
Oh btw the car is lowered as well :)
Will 18x10.5" wheel work on the fronts ?AZ2ENVY 09-28-2009, 04:54 PM Does anyone know if ill have any issues running 18x10.5 56mm offset wheel on the fronts ? If not what size tire should I run ? Thanks in advance ! Oh btw the car is lowered as well :) Injuneer 10-01-2009, 06:21 AM That wheel would have close to an 8" backspace. Now tell us what kind of car its going on. If its a 4th Gen, its going to require about a 1/2" spacer. I'd guess that its going to rub heavilly on the inner fender liner, particularly when the wheels are turned to the side, or you hit a severe bump. slomarao 10-01-2009, 11:57 AM why do you want to run such a big rim in the front? AZ2ENVY 10-01-2009, 05:45 PM Oh sorry lol yea its going on a 4th gen Camaro LT1 . Theres a guy running a 3/16's spacer on the fronts with a 295/35 tire and no rubbing or the lip sticking out . Im gonna run this because the 18x10.5 wheel im getting has about a 3" dish on it and I want it on all 4 corners :) Ill provide pics of said setup if needed to see as well . BLK96Z28 10-11-2009, 06:22 PM Oh sorry lol yea its going on a 4th gen Camaro LT1 . Theres a guy running a 3/16's spacer on the fronts with a 295/35 tire and no rubbing or the lip sticking out . Im gonna run this because the 18x10.5 wheel im getting has about a 3" dish on it and I want it on all 4 corners :) Ill provide pics of said setup if needed to see as well . I'd like too see pics! xxteenobesexx 10-19-2009, 09:43 PM def wanna see it too AZ2ENVY 10-20-2009, 04:22 PM Just got the wheels in still waiting on the tires and spacers . Heres a few pics so far :) http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_0013.jpg http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_0015.jpg http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_0011.jpg http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_00042.jpg http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_0003.jpg http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_00022.jpg http://i2.photobucket.com/albums/y10/ZL1LT1/DSC_00012.jpg jer4251 10-22-2009, 07:11 PM 20x10.5's 285/30's http://i75.photobucket.com/albums/i296/jer4251/97%20SS/0408091736a.jpg http://i75.photobucket.com/albums/i296/jer4251/97%20SS/0408091735b.jpg http://i75.photobucket.com/albums/i296/jer4251/97%20SS/0408091737a.jpg Camaro350z28 11-06-2009, 02:58 PM you got the rubber on these wheels yet? this is what i am looking into doing as well. matt14 11-07-2009, 02:27 AM are those deep dish c5's? if so whered u get them and are they gunmetal? Camaro350z28 11-07-2009, 02:10 PM they look like it, and c5 y2k's... hoping he has rubber on these i wanna see the final! jer4251 11-07-2009, 03:22 PM their deep dish C5's black with machined face 69z-28 11-15-2009, 08:20 PM i just test fit an 18x10.5 on the front of my T/A today and was not comfortable with where the wheel and sidewall of the tire is in relation to the spindle/ball joint. i then tried it with one of those ghetto ass wheel spacers (thinkin its about 3/16 like said above) and it was better but there's no good way to perfectly center the spacer between the wheel and rotor because its not lug or hub centric. just kinda got sandwiched between the rotor and wheel, which i suppose isnt a huge deal, although seems ghetto to me. also, i still have stock length wheel studs, and seemed like the lug nuts grabbed a decent amount of the studs thread, but obviously about 3/16" less than it should have. anybody doing it with stock studs and no issues? like i said... seems kinda ghetto and not too safe... Injuneer 11-15-2009, 11:13 PM You can get quality hub-centric spacers from: http://www.skulte.com/ Tell them what you need, and they can make them. You have to have at least 1/2" of thread engagement in the "hex" portion of the lug nut. Anything less is dangerous. 69z-28 11-16-2009, 12:44 AM thanks Fred. one other question... like i said, the wheel and tire were EXTREMELY close to the spindle and the castle nut to the ball joint, although they did clear without rubbing. my question is: while driving, going over bumps, making turns and whatnot, will the spindle actually move and have a chance of hitting the wheel and/or tire? im thinking since the wheel and all front suspension moves together that NO, it wouldnt rub, although im wondering if certain circumstances would cause this to be an issue. i also had a 305-35-18 on there (bought 4 rears), which will be swapped with a 275-40-18 so that should help. but still weary and wanna take all steps to ensure i wont have any issues, or if i will, that i swap to the proper 18x9.5" wheels before something stupid happens that could have been avoided:) Injuneer 11-16-2009, 06:26 AM If the spindle moves relative to the steering knuckle, the bearings are shot. | ||
