cost to run a 2nd battery and 200amp alternator?
Old Aug 19, 2002 | 05:04 PM
sleeperZ96BT's Avatar
Post cost to run a 2nd battery and 200amp alternator?
looking at doing this as my system warrants it (orion XTRPRO 2400, PPI PC650 and PC 275). was wondering what the cost of parts and labor might be roughly.
thanks,
brian
Old Aug 19, 2002 | 07:06 PM
rthompson's Avatar
Post
$240 for the Alt, and $75 for the solenoid to run the second battery, and another $150 for the battery. Do it yourself and you are golden.
Old Aug 19, 2002 | 10:45 PM
Post
where can i locate an 200 amp alternator? and will it mount in the stock location?? do they make them any larger than 200 amps at a reasonable cost?
brian
Old Aug 19, 2002 | 11:19 PM
dust6928's Avatar
Post
240 is cheap and that is about as big as they can wind in a stock housing. you realize it takes about 25-35hp to run an alternator that large.
Dustin 95Z28 dynomax quietflow,rk y's,!cat,gmcai,tb airfoil, 4.10's,6spd,mac sfc,mac lca,mac pr,160stat,hpp,accel wires,whsp maf, lt4 k.m.,ls1 ds,valeo clutch
Old Aug 20, 2002 | 04:57 AM
rthompson's Avatar
Post
mralternator.com
Soundillusions.net
The ultimate in caraudio.
Sony, Arc Audio, Infinity, Adire Audio, A/D/S
Old Aug 20, 2002 | 05:37 PM
Post
2 more questions:
1) mr alternator said 200 amps is $260 to my door, anywhere cheaper?
2)if i ran a yellow top battery only would i be ok? or should i really run 2 batterys?
thanks,
brian
Old Aug 21, 2002 | 03:50 PM
Izod's Avatar
Post
I ran 2 15" MTX 5000s on an MTX2150x and another 75x4 amp, on nothing but stock wiring and a yellow top. just get a friggin yellow top, and don't be retarded, watch your volts and hit att. at stop lights. lol.
Old Aug 21, 2002 | 07:09 PM
rthompson's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Izod:
I ran 2 15" MTX 5000s on an MTX2150x and another 75x4 amp, on nothing but stock wiring and a yellow top. just get a friggin yellow top, and don't be retarded, watch your volts and hit att. at stop lights. lol.</font>
so your situation was anywhere close to his because???
He is going to be running more power in his midsize amp than you were total... that is nothing like what you were doing.
Old Aug 26, 2002 | 08:00 PM
Izod's Avatar
Post
Regardless of what you say, a second battery is still a myth, its worthless.
Old Aug 26, 2002 | 08:28 PM
megabass's Avatar
Post
Regardless of what you say, a second battery is still a myth, its worthless. </font>
Why would a second battery be worthless? Seems like a good idea to me.
Anyway, BT, take a look at what a buddy of mine did
http://www.ls1.com/forums/showthread...hreadid=150633
[This message has been edited by megabass (edited August 26, 2002).]
Old Sep 9, 2002 | 05:41 PM
Post
any pages that show how to install a 2nd battery, as well as any tips for me to do it? its getting close to that time for me and need an install page/advice on how to do it.....i have a yellow top as my 2nd battery and i plan on ordering the summit battery relocation kit and an isolator. which bring me to my next question, who makes isolators and where can i get em?
thanks,
brian
Old Sep 10, 2002 | 08:40 PM
Post
well, based on the fact that i am running ~3000 watts rms (hehe) looks like ill need a fairly large one, as in the biggest one they make. the $75 one wont cut it apparantly...240 amp is $180 and another 20 for the GM harness....i may just pony up the money for a system regulator (~$80 more).
http://www.thezeb.com/caraudio/light...isolators.html
what do you guys think i should do? BTW, rthompson i sent you mail
brian
Old Sep 10, 2002 | 10:01 PM
guyomatic's Avatar
Post
If you can't get an answer from here, you better find an electric engineer
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
96 Z, T-tops,M6,K&N FIPK,HPP+,160*,Borla Cat-back,52mm BBK TB, TB by-pass,Edelbrock shorty headers,Granatelli MAF,Accel Extreme wires,NGK TR55's,FireBall Coil
94 Taurus SHO(For sale in Toronto)
92 ZX-7
Audio:
Alpine Head Unit, MP3
Hifonics Z700 amp
Infinity Kappa 6.75" 2-ways
Kaption SPL 10
Kenwood KDC-C565FM 10 disc changer
Optima Yellow top in rear
Old Sep 11, 2002 | 05:52 AM
Post
thanks man, i see you have a yellow top in the rear (lol), howd you run that and is it your primary battery or 2nd battery?
thanks,
brian
Old Sep 11, 2002 | 09:13 PM
limige's Avatar
Post
thats' an awesome price for the alt. trust me...
as for the 2nd batt. do this, take your stock batt out and buy two new batts' both same size and brand. do this and you won't have to buy an isolator, i garuntee you...
in my avenger i had 1 15 on 4000 watts and another 300 watts to the highs, before i ripped everything apart i had a total of 4 battery's in there all running on the stock alternator. no isolaters no problems, front batt was a red top, 2 yellows in the back, and a duralast for some extra help.
as for 2nd batt a myth, your an idiot....
unless you are running regulated amplifiers like zapco. most are not.
lets think for a second. alt charges at 13.8-14.4 volts, when the bass hits it pulls all the juice it can, roughly 60-70 amps per 1000 watts, your alt can't produce the power for a quick bass hit fast enough so the voltage drops to 12.4-13 volts before getting into the battery. at this time the alt is doing nothing, your drawing off your battery.
so, some amps will fry or clip bad below 11.4 volts, most shut off right around there as well. in order to keep voltage as high as possible you need more battery's to try and hold the voltage.
adding more batteries is easy, run a peice of 1/0 wire (buy from www.darvex.com) to the rear battery, hood positive of front battery to the pos of trunk batt. ungrade your ground under the hood to 4 gauge or 1/0 to the body. and do the same in the trunk 4 gauge or 1/0 ground to the body. the seatbelt bolts are good spots to ground. anyway, the run wires off the back batt to your system. oh and upgrade to 4 gauge from the alternator to the battery as well.
do this and your good to go, general rule of thumb is 1 extra batt per 1000watts.
