z0s0
09-22-2009, 08:07 PM
My '95 Z, all stock, has a rattle in the front left hand side when I hit bumps or imperfections. I am almost positive that it is the bolt that holds the swaybar (on the drivers side) to the A-arm. The bolt has bushings on it and a nut at both ends, and it is loose (it can be moved by hand up and down about 1/2" - 1"). Not sure, but I think maybe I lost a bushing in there somewhere? I've tried getting the nut/bolt off using a ratchet on one side and wrench on the other and it is NOT moving..lol. Not even a little, even after a generous application of wd40 and letting it set for a day. I may have to just cut it off with a dremel. Anyway, my question is, should I replace this bolt/bushing set with the stock part, or is there a better upgrade...I've been seeing a lot on here about poly bushings for swaybars, which is why I'm asking. Open to suggestions..I need to do this soon the rattle is driving me nuts.
