rotating tires???
Old Jan 18, 2003 | 11:58 PM
gearslammer's Avatar
rotating tires???
I can't see with the wear of the way some (probably most) of us drive on this board that tire rotation would serve any purpose considering the extreme wear on just the rears.
Comments???
Old Jan 19, 2003 | 10:53 AM
Black01_Z's Avatar
After marking my territory at numerous stop signs, every three months I rotate the tires to keep the tread even. Besides this way you double the life of your tires.
Old Jan 19, 2003 | 11:34 PM
SS SLP2's Avatar
ALSO SUGGEST FOLLOWING INFO TO OBTAIN TIRE MILAGE
{NOTE PIC OF TIRE] HAVE 30 K ON THESE F-1
RUN 44 PS1 ALL AROUND ALL TIME CHK EVERT 2-3 WKS
ROTATE FRONT TO BACK @ EACH 5K -CROSS SIDE TO SIDE AND FRONT
BACK @ EACH 10 K >> [[ DO NOT CHANGE DIRECTION OF ROTATION-
YOU MUST REMOVE TIRE AND FLIP IT ON THE RIM }] THESE ARE WORN
PERFECT CAN NOT TELL RIGHT FROM LEFT OR FRONT FROM REAR
MAINTAIN ALIGN SPECTS @ CAMBER =O.50 DEG ,
CASTER =4.50 DEG ON LEFT SIDE, 5.00 DEG ON RIGHT,,
TOE=1/16 INCH TOE IN
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
