built 91 L98 350 , Vortec heads SS 2.02/1.6
Old Jan 18, 2003 | 07:47 PM
TVP's Avatar
TVP
$2200 ... I'll entertain offers but you'd be hard pressed to build it cheaply as it's listed ...
below are the prices , itemized for your convenience , I'm not parting it out !!! I'll sell the heads 1st .. then separate the short block..
Motor ....short block $1395
$150 1991 L98 Roller 350 core
$350 machine work , hot tanked , bored .030 , magnafluxed and checked for clearances , cam bearings installed , crank turned , etc
$150 Forged Nodular LT-1/ZZ4 Crank , .010/.010
$100 LT-1/Vortec powdered metal rods , magnafluxed and checked for clearances
$225 Speed-Pro/TRW forged flat top pistons
$80 rings , Sealed power , Moly Plasma
$90 bearings , TRW/Federal Mogul Racing Series
$150 gasket kit Fel Pro
$50 ARP rod bolts
$50 LT-1 roller lifters , web and retainers
$65 Cylinder head studs and bolts
$65 ARP main studs for use w/ windage tray
Heads $900
$300 Vortec Cores ..Casting # 906
$300 machine work , cut for bigger valves , pocket porting , viton seals , tap for studs , mill deck .030
$65 2.02 and 1.6 stainless under cut valves
$50 .600 lift springs $30 chrome moly retainers
$20 offset keepers
$35 Viton seals
$35 ARP studs
$40 Hardened push rods
$20 Chrome moly guide plates
Old Aug 19, 2003 | 02:39 PM
TVP's Avatar
TVP
ttt
thanx
TVP
Old Aug 20, 2003 | 12:11 PM
TVP's Avatar
TVP
ttt
thanx
TVP
Old Sep 8, 2003 | 03:35 PM
TVP's Avatar
TVP
ttt
thanx
TVP
Old Sep 26, 2003 | 12:48 AM
jbbiggs's Avatar
sent mail
Old Sep 30, 2003 | 05:36 PM
TVP's Avatar
TVP
ttt
TVP
Old Oct 3, 2003 | 03:53 PM
TVP's Avatar
TVP
ttt
thanx
TVP
Old Nov 17, 2003 | 03:47 PM
TVP's Avatar
TVP
ttt
thanx
TVP
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
