Any help would great again =/
Old Aug 16, 2009 | 03:23 PM
zackthespaceboy's Avatar
Question Any help would great again =/
This is an update from my last thread I put up.
My 91 camaro RS with a v6 3.1 engine still isn't running. I checked the fuel pressure and its reads the correct PSI. I turned the rotor to check the timing chain and that was fine also. I reset the timing marks and that still didnt do it. Compression is fine also and there's a good healthy looking spark. Still doesnt want to start.
Is there anything else I should be checking for?
Old Aug 21, 2009 | 07:56 PM
mdenz3's Avatar
Get a loaner Noid Light set from Autozone and see if the injectors are pulsing.
Noid lights are just lights that plug into the fuel injector connector and light up when the ECM pulses the injector.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PROJECT X
Apr 17, 2015 12:13 AM
gto4u2
Mar 14, 2015 06:05 AM
cmyname1
Feb 16, 2015 08:33 PM
