Ryabut98
09-01-2002, 02:11 AM
Original setup.. Stock Headunit, Stock Amp.. Stock speakers and a 10" Sub with the help of PAC-OEM.. All's working fine...
Today I decided to work on the car...
The install..
I installed a Din HeadUnit Kenwood KDC-MP8017 along with a 1/2 din Kenwood Equalizer... with a custom kit .. Looks perfect... I actually amazed myself.. http://web.camaross.com/bb/biggrin.gif !:worship: Got that one all fitted ...
Wiring...
Got all the wires connected. I used the Preout of the Kenwood Headunit to the input of the Equalizer... then connected the preout of the eqaulizers to the stock wiring... I realized this mistake after reading one of the threads on this board that the stock AMP only turns on when there's a speaker level signal coming in... I knew something's wrong because when I connected everything.. I only have the Subwoofer working.. all other speakers arent, which gave me the clue that the Monsoon amp wasn't turning on. This is when I found out about the Speaker level signal it needed to turn on. (Can someone please confirm this).
Re-Wired...
Ok.. Switched the wiring setup.. The Monsoon amp is up and running again.. sounds great... I connected the amp of the sub to the headunits preout. For now, I bypassed the equalizer all together until I can get enough cash to replace the stock wiring and the stock Amp. I think I can use the Equalizer to control the sub from the front... but maybe later..
The problem..:no: :no:
The sub won't do what it used to do. There's sound coming out of it but its working like a regular speaker.. I checked the Amp for the sub and its working fine.. I didn't touch any of its settings so It couldn't have been that. Its also Powered ON (for the smart a$$es). http://web.camaross.com/bb/biggrin.gif
Again, I connected the SUB -AMP to the pre-outs of the Headunit... I didn't change anything else.
ANy idea what I did wrong? Please? Thanks!
The install..
Wiring...
Re-Wired...
