entry level stuff for sale
ChameleonGreen
09-02-2002, 06:15 AM
Metra HU Kit 3320 - $10 shipped
this is the normal kit, not the recessed kit, that you can pick up at your local store for like $15. brand new.
Rockford Fosgate 125.2 amp. 98' or 99' model. 62.5rms x 2 at 4ohm, 125rms x2 at 2ohm, 250rms x1 at 4ohms. you'll need to buy an inline fuse and fuse holder. amp hasn't been used in about two years, but i tested it and it still works just like it used to. $75 shipped
Boss REV 785 4ch amp. this amp is rated at 50rms x 4 at 4ohms, 100rms x 4 at 2ohm, and 200rms x 2 bridged. boss is a flea market brand so it probably doesn't quite put out that much, but something close. i havn't used this one in about two years either, but my friend bought one at the same time and he's still using it and it still works fine. make sure you know how to set your gains properly if you buy this, it's really easy to over do it on this amp. minor cosmetic scratches, you'll need an inline fuse holder and fuse. $75 shipped
Rockford Fosgate 10inch 4ohm SVC sub. 98 or 99 model. 200rms, 400max. i ran this off the RF amp above in a cheapo stealthbox. that combo hit pretty decently. $40 shipped.
2 Audiobahn AW1200X 12inch subs. 4ohm DVC. 700rms, 1400max. about a year old each. this was their high excursion sub for spl use. they've since changed the model names to 1200Q i think. $90 each shipped
everything comes in it's original box and i should still have all the manuals
nin@austin.rr.com if you're interested in anything or have questions
George
