Need PAC-OEM Details
I know the PAC is used for switching from a factory amp to an aftermarket amp, but can the PAC be used on a stock deck system with no factory amp to get some RCA outputs?
Due to SOME MOTHER F**KER BREAKING MY WINDOW AND STEALING MY HU AND MY BEST 100 CDS
, I have to use the stock deck until I can afford a new HU.
If the PAC can be used, what pieces do I need?
Thanks, George
, I have to use the stock deck until I can afford a new HU.If the PAC can be used, what pieces do I need?
Thanks, George
Yes, the OEM-1 can get you a set of RCA outs from just a stock GM HU.
ALL 4th Gen. Camaro's need the actual OEM-1 and AMP-RCA cable.
If it's a '93-'96 w/Bose HU, you'll need the ADD-GM21 cable.
If it's a '97-up w/Monsoon OR non-Monsoon HU, then you'll need the ADD-GM21C cable.
