New and Used Parts for OMCs JOHNSON 85,90, outboards.
Newengland
08-08-2009, 11:09 AM
complete Power Trim & Tilt unit for Johnson/Evinrude 85 to 150 HP motors. $400
2 each Complete lower units for Johnson/Evinrude 85 to 150 HP motors $700 each
(SOME USED STUFF)
2 ea Johnson 90 HP upper metal housings $50.ea
3 ea Johnson 90 HP Lower Unit Housings $50.ea
1 Ea Johnson 90 HP fiberglass cowlings. $50. Ea
1Ea Lower plastic cover for Johnson 90 HP $50.
3 Each Motor mount Brackets with serial #s for Johnson 90 Hp $150.Ea.
Recoil Starter Assembly and 2 blade propeller for
Merc/Force 9.9 or 15HP outboard motor.
Asking $99.
New Parts for OMCs JOHNSON 85,90, outboards.
Teleflex Black 15ft t shift/throttle cable OMC new 1 ea. $15.
Teleflex Black 23 ft shift/throttle cable MERC new 1 ea $25.
Teleflex Marine Trident Blue Wet Exhaust Hose 3 dia X 50 lg. $50. .
3 each #323664 Spline Gear $99.ea.
1 Ea Ignition Coil Kit # 583737 $99.ea.
1 Ea Voltage Regulator Kit # 173640 $189.ea.
2 Ea Helical Lower unit Gear sets 340490 $199.set
2 Ea Rubber Exhaust Gaskets $10. ea
1 Ea Complete 90 Hp Gasket set # 139300 $50.ea.
6 Ea Gaskets # 317914 $6 ea.
2 Ea used OMC Stator #583669, #583672, $50 ea.
2 Ea VRO Pumps #175161 $175 ea.
1 Ea Timer Base Kit #583376 $99.
1 Ea New Rectifier/Regulator Kit # 395391 $135.
1 Ea Used Rectifier/Regulator # 395391 $85.
1 Ea Gasket # 359-317955-1 $6.ea
9 Ea Gaskets # 194-321727-1 $6ea
5 Ea Gasket # 2Ea
Gasket # 436-323459-1 $6.ea
4 ea 90HP Rod Bearings $50. set
2 Ea Ignition coils #582508-0560-0A $99. Ea
1 Ea Stator $100.
1 Ea Flywheel $100.
ACCELL Distributor & Rotors Caps for Mallory $18. set.
Felpro Chevy 305/350 4 boat rubber valve cover gaskets 1 pair PN# VS12869R New $10.
Felpro Chevy 305/350 Cork/rubber valve cover gasket 1each New. $4
NEA PN# VS2335 Chevy 305/350 4 boat Marine Exhaust Manifold gaskets. New. 1 pair . $12.
Felpro Mercrusier Chevy 305/350 Gasket kit assorted not complete (head gasket missing) $10..
Bronze 11/2 Prop Nut $3.
Two Power tilt motors for older OMC I/O outdrive. Unknown condition. $40 for both
Make me an Offer for some or the WHOLE LOT!
Newenglandcharters@maine.rr.com
