bwarren337
07-28-2009, 11:54 PM
I have a 1999 Camaro Z28 with 88,000 miles about to put in an Ls6 manifold and ported throttle body, I have an SSRA, Slp lid, K&N Filter, also have 3" long tube headers with 3" pipe going to 3" cutout. front 18x9.5" rear 19x10" tires...
my question is what kind of cam would you recommend? I was kinda thinking the MS3 or something similar to that... if cam was to be swapped what else would yall recommend to replace?
Kraest
07-29-2009, 12:18 AM
Futral Motorsports F13 or F14. The high-lift versions run awesome if you don't plan on doing milled heads .
bwarren337
07-29-2009, 08:57 AM
wha tkind of HP could I expect from an F13 or F14
johnny6
07-29-2009, 12:42 PM
Look at his signature:
1998 Z28 M6 F14HL Cam 415/395 12.24@116.15
bwarren337
07-29-2009, 01:23 PM
would I need to replace timing chain, oil pump or water pump while im doing the swap..
johnny6
07-29-2009, 02:31 PM
Definitely change the timing chain, no need to change waterpump unless you are having issues with it. I do recommend changing the oil pump since you have 88k miles.
Kraest
07-29-2009, 06:05 PM
On any LS1 cam-swap, it is highly suggested that you replace the oil pump with an LS6 or ported LS1 pump and the timing set with an LS2 set or something similar. Also, upgrade the pushrods, springs, retainers, locks, etc.
Mike
Kraest
07-29-2009, 06:06 PM
Also, the H/C/I Vette also had an FMS camshaft (F-15) (not suggested for a daily driver)
I'd get the F-14 HL again. Awesome driveability and insane power/midrange. The car felt like it was on nitrous all the time.
Vids of the F14-HL car:
http://i205.photobucket.com/albums/bb191/kraest/th_MVI_2350.jpg (http://s205.photobucket.com/albums/bb191/kraest/?action=view¤t=MVI_2350.flv)
http://i205.photobucket.com/albums/bb191/kraest/th_MVI_2349.jpg (http://s205.photobucket.com/albums/bb191/kraest/?action=view¤t=MVI_2349.flv)
http://i205.photobucket.com/albums/bb191/kraest/th_MVI_2348.jpg (http://s205.photobucket.com/albums/bb191/kraest/?action=view¤t=MVI_2348.flv)
http://i205.photobucket.com/albums/bb191/kraest/th_MVI_2345.jpg (http://s205.photobucket.com/albums/bb191/kraest/?action=view¤t=MVI_2345.flv)
Mike
johnny6
07-29-2009, 06:47 PM
Don't lie, you miss having an LS1 don't you? :lol:
Kraest
07-29-2009, 10:33 PM
Definitely miss the raw power. :(
M3 FTW. :(
bwarren337
08-01-2009, 08:53 PM
would rocker arms be suggested as well.
johnny6
08-01-2009, 11:18 PM
Nope, stockers are good.
bwarren337
08-02-2009, 10:35 AM
would putting a 160 degree thermostat on help any?
Kraest
08-02-2009, 12:46 PM
Nope. Just get the fans turned on early when you get the tune.
bwarren337
08-02-2009, 11:50 PM
are used cams bad to use or would you suggest getting a new cam
AL SS590 M6
08-03-2009, 07:18 AM
Nothing wrong with using a used cam. Just inspect it carefully for wear, knicks, or deep scratches.
bwarren337
08-03-2009, 08:06 PM
well in about a month or so when the money gets right ill be putting in a new cam, but till then I'll just be reading and asking ?'s appreciate all of the input and answers..thanks
