$hawn
08-27-2002, 11:42 PM
Does the length of speaker wire matter or make any difference, if so would you want it to be longer or shorter?
93 Z28 Patriot Red A4
Is the speaker wire length important?$hawn 08-27-2002, 11:42 PM Does the length of speaker wire matter or make any difference, if so would you want it to be longer or shorter? ------------------ 93 Z28 Patriot Red A4 NineSevenWS6 08-28-2002, 12:00 AM Doesnt matter.... eyeoutthere 08-28-2002, 01:10 AM You don’t want an excessive amount of wire because it will increase your chance of interference. Just use what you need. LS1 RULZ 08-28-2002, 07:05 AM Speaker wire doesn't pick up noise like an RCA cable can. megabass 08-28-2002, 09:28 AM The length isn't as important as the size of the wire. 97FormulaWS-6 08-28-2002, 10:09 AM Well, look at it this way.... every wire has a resistance per foot, that means every foot you add in length will add X ammount of Ohms. Typically in speaker wire it's very small but can add up, especially with High power systems, and too small wire. If you have large enough wire for your speakers the length doesn't really matter that much. Mike ------------------ 1997 Formula WS-6, 1 of 473 Mods: P&P MAF, Pro-5.0, SLP LT4 Clutch, 200 Amp Alt, TB Bypass, !AIR, !CAGS, 160 therm, CSI WP, PS Cooler, GMS STB, Cutout, TCI LineLock, ES Swaybar/Trans/TA Bushings, 5%R/20%S Tint, Painted Calipers, Custom Clear Tail Lights/Corners http://camaroz28.cardomain.com/id/97formulaws6 | ||
