Riddle me this
Old Jul 21, 2009 | 04:25 PM
Purple Poncho's Avatar
Riddle me this
So I've had the Vortech on for 9 years or so and I just noticed this now.
The stock opti system has one vacuum hose to the intake and one to the intake rubber elbow. I imagine this is to blow and suck air throught the opti.
You can't do that with a blown car.
I noticed my setup has both vacuum lines to the intake so both line are "pushing" air into the opti.
Will this kill an opti faster? How do you guys run the vacuum lines to the opti?
Old Jul 21, 2009 | 06:48 PM
MikeGyver's Avatar
Just run the opti air inlet hose to before the supercharger, and run the vacuum hose to the manifold with a check valve, so it doesnt boost the opti (as it should be)....
The setup just draws fresh air through the opti to vent ozone, moisture, etc.
Old Jul 21, 2009 | 07:46 PM
jay_rich's Avatar
Ive thought of this too, i put mine into my pressure side...i think this may be causing my boost leak and the reason why i cant see over 8psi!
Jay
Old Jul 22, 2009 | 09:59 AM
ak95ta's Avatar
The Vortech installation manual clearly shows routing that hose to the suck side of the blower. In 95, the ruturn hose for the opti has a check valve on it from the factory. http://www.vortechengineering.com/su...0-%20GM%20Cars Page 13, paragraph H
Old Jul 22, 2009 | 12:18 PM
Kevin Blown 95 TA's Avatar
Jay
yeah, plug that massive leak and you'll get back your missing .001 # of boost.
Old Jul 22, 2009 | 02:21 PM
I have the Brad Brand hard intake pipe and it doesn't have a vacuum nipple for the opti. I will have to put one on.
