Looking for a good "rock" sub
nSSane
08-25-2002, 11:53 PM
My intent is to add a 10in sub to the factory system. What is a good sub for mostly "rock" music and which amp would you put with it?
Also, could you give a brief reason what makes it good for "rock" and why you choose it.
Thanks for the opinions
Bill
firebirdude
08-26-2002, 06:19 AM
It's not really the sub that will matter the most. It's the install and the type of box you have. For mostly rock, I would go with a sealed enclosure. Do you have t-tops? Do you plan on keeping what little trunk space we have? I ask because MTX (and several other companies) makes a sealed box that fits right into the left hatch area. It utilizes room that normally would not be used. For just one 10".... I would go with that. Post back with your option and I will help you some more.
LS1 RULZ
08-26-2002, 07:04 AM
I'm using a JL Audio Vantage Stealthbox with an Alpine Type-S subwoofer. I was using a JL Audio 10W3 but the Alpine blows away the JL. The JL is an excellent sub but the Alpine seems to be a MUCH better match for the .6 cubic feet of the Vantage enclosure.
http://images.cardomain.com/installs/133000-133999/133032_89_full.jpg
As for an amp...Look into a class D subwoofer amp. I'm using an MTX Thunder 6500D. The amp pumps out 600W into the Alpine's 2ohm load. I only listen to ROCK (no cRAP, hip-hop, or any of that other BS) and it sounds GREAT!!!
