2001 Z28 600 rear wheel horsepower!
Old Jul 9, 2009 | 04:31 PM
compta's Avatar
This is an original Sunset orange metallic car it is rare because of its color and options it is a stripper with t-tops. It has new paint. I am looking to trade for 2004 and newer Altimal, Maxima, Accord, Camry +cash. The rearend, motor, and tranny with converter are worth 7K in my car alone. There is around 10K invested in my car not including the price of the vehicle. This car is fast! It still needs the exhaust welded up so will require a trailer. The car also has a new kenwood deck. I am asking 10K obo. please call or text 512-913-2846 please leave a message if I do not answer. The oil leak is fixed it was the oil pressure sensor just needs the exhaust welded back up. I have $11194.84 in reciepts not including the control arms, strut tower brace, subframe connectors, lowering springs, race muffler, rims and tires. i will take 10k obo or trade. Thanks
MOTOR
-rebuilt LS1 with less than 1000 miles on it
-diamond forged pistons
-Forged H-Beam rods
-36lb injectors
-walbro 255 fuel pump
-Fully ported 5.3 heads milled to 45cc that flow 315cfm on intake at .550 and 232 cfm on exhaust no pipe on a 3.9 inch bore 2.02 1.57 valves patriot gold springs
-new melling oil pump
-Double roller timing chain
-brand new LS7 lifters
-comp hardened pushrods
-arp rod bolts and head bolts
-trex cam shaft v1
-11.1 compresssion
-texas speed 1 7/8 ceramic coated long tube headers to off road y-pipe to an electric cut out
-ls6 intake
-80mm throttle body
-slp lid
-ported mass airflow sensor
-new water pump
-new oil pressure sensor
-new a/c system (compressor, oraphus tube, and condensor)
Transmission
-yank 3400 stall converter
-fully built 4l60E
rearend
-moser 12 bolt 33 spline axles 1350 yolk
-3.73 gears
Nirous
-200 hp wet shot cold fusion nitrous kit
-upgraded 15 lb bottle filled never used
-msd window switch
-msd timing twister included not installed yet
-zex remote bottle opener
-need to be finished installing
chasis and wheels
-Y2K vette wheels chrome 18s in the rear 17s in the front.
-1.5 lowering springs
-tubular control arms
-adjustable pan hard bar
-hotchkis rear and front sway bars front is not installed yet
-tubular weld on seb frame connectors
-edelbrock 3pt strut tower brace
Old Jul 11, 2009 | 11:15 AM
compta's Avatar
bump!!
Old Jul 11, 2009 | 11:17 AM
Outrun's Avatar
Pics?
Old Jul 11, 2009 | 01:02 PM
compta's Avatar
Originally Posted by Outrun
Pics?
got an email
Old Jul 12, 2009 | 08:39 AM
95Panther's Avatar
Why was the car repainted? How many miles on the car? Where are you located?In your earlier test post it sounds like you have been driving the car ,so what happened to the exhaust?Also you posted earlier you would sell for $8500? I'm obviously interested is the reason for all the questions.
Old Jul 12, 2009 | 10:22 AM
compta's Avatar
the original rearend locked up at 20 mph on a dirt road so the car slid into a fence no body damage just light scratches that is why it was repainted and that is why it now has a 12 bolt in it. the car has 13X,XXX miles on it. yes it was my wifes daily driver i thought it blew the rear main seal that is why i was asking 8500. It happend to the oil pressure sensor so i fixed it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
Jon657
Jul 19, 2002 07:51 PM
