OneFreakZ
06-30-2009, 11:25 PM
like the title says is it possible, i have two tires laying around, my 335 tires are shot..
275/40r17 tire on 17x11 wheel possible??OneFreakZ 06-30-2009, 11:25 PM like the title says is it possible, i have two tires laying around, my 335 tires are shot.. Injuneer 06-30-2009, 11:33 PM Most tire manufacturers recommend a wheel width of 9.0" - 11.0" for a 275/40-17. If the tire manufacturer tells you that, for the specific tire you are using, it will be fine. Might look a bit "stretched", since a 275 is about 11" wide, and an 11" wheel is actually about 12" wide when you include the flanges that retain the tire beads. OneFreakZ 07-01-2009, 12:11 AM how can i find out to see if it fits with the tire manufacturers . tire rack maybe??? OneFreakZ 07-01-2009, 12:21 AM i have two Eagle F1 GS-D3 tires tire rack says (rim width range 9-11'') for the 275/40r17. so i guess im ok right?? Z28avalanche 07-01-2009, 08:02 AM I use 1010tires.com Enter your tire size and it will tell you what size wheel it should be on Injuneer 07-01-2009, 11:42 PM Yes. Tire Rack lists the GS-D3 and every other 275/40-17 tire I looked at (maybe 6 or 7) as 9.0 to 11.0" OneFreakZ 07-01-2009, 11:45 PM awsome ill be mounting tires friday. Injuneer thanks big help | ||
