Help!
Old Aug 14, 2002 | 08:27 PM
Red97LT1's Avatar
Question Help!
Some how i managed to break the metal pin in the factory wiring harness.I think that it is one of my speaker wire pins.The wire pulled out and while trying to get the pin out,i some how crushed it.What can i do to remedy this?
30th anniversary Z28!
Old Aug 14, 2002 | 10:34 PM
PaulN64's Avatar
Post
http://www.installdr.com use this to find out which wire it is that you cut and just splice it directly to the wire harness from the radio.
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
Old Aug 15, 2002 | 08:33 AM
Lynxis's Avatar
Post
yeah really...
just check to see (visually look at the wiring harness) what wire is connected to the broken pin.
the check the other part of the harness and see what part would be connected to the pin that is broken...
then, cut the two wires before the wiring harness. then twist the two of them together and either solder them or get a wire nut and tie them together and then put electrical tape over the splice
viola..... yer done
