compression
jkmj999
06-19-2009, 04:24 PM
don't know too much about mechanic aspect of a car engine... bought a used 91 Chevy z 28 , drives fine. but sometime waiting @ red light , engine idles rough for few seconds and it happens in a few seconds interval. if i turn on the A/C , it idels ok . there is oil leak @ the back top part of the egine . i changed the spark plugs already. and my friend told me it could be compression issue.
Me>you
06-19-2009, 11:17 PM
Well first, this belongs in another section. This particular thread was posted in the LS1 engine section, the LS1 is a far superior engine to the one you have in your camaro.
All that aside, there are a number of different things i'd check before a compression test for a rough idle. Start with those string like things attached to the spark plugs you changed, and work your way up.
Kraest
06-20-2009, 08:07 AM
Moving...
Z28SORR
06-22-2009, 10:28 AM
Also check your EGR and evap. canister.
