Front vents of A/C not working
purplehaze45
06-18-2009, 07:05 PM
I have a 95 z28 and the air only blows through the top and bottom vents, but not through the front... the air is cold just not blowing out the four front vents. anyone know what this could be?
n2ceptor
06-18-2009, 07:36 PM
http://shbox.com/1/vac_check_valve.jpg
Check this valve.... Passenger side by fire wall... Pic courtesy of Shoebox..:)
purplehaze45
06-18-2009, 07:45 PM
what exactly would i be checking it for...?
2001NBMZ28
06-18-2009, 07:54 PM
Make sure they're all connected and not brittle causing a vacuum leak.
shoebox
06-18-2009, 09:45 PM
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
purplehaze45
07-11-2009, 09:34 AM
if its not a vaccum leak then what else could it be
shoebox
07-11-2009, 10:12 AM
Is that a hypothetical question or have you proved you are getting good vacuum to the mode selector?
purplehaze45
07-18-2009, 11:57 PM
i have checked it and its not a vaccum leak
