Removing Pilot bushing?
Old Jun 6, 2009 | 04:21 PM
ss#1230's Avatar
im putting in my spec 3+ right now...
how do i get the pilot bushing out? i tried a little hook tool ive got, but it's in there pretty tight!
is it a must to replace it?
Old Jun 6, 2009 | 05:06 PM
Kevin Blown 95 TA's Avatar
You can get an attachment for a slide hammer and yank it out or pack it with grease and use a hammer & rod the size of the inut shaft to hydraulicly force it out or use your little finger to just pull it out or super glue a piece of string to it and hook it to a team of horses and let them pull it out - there's probably a super expensive GM tool to get it out...
Old Jun 6, 2009 | 10:50 PM
Rising Phoenix's Avatar
Autozone has a tool you can rent called a "blind hole puller". It's basically a slide hammer fitted with an adapter that expands when you thread it further down on the slider hammer. Just put it through the pilot bushing/bearing, open the "jaws" as far as they will go, then go to town with the slide hammer. On my car, the bushing was in there so tight that there is no way the hydraulic method Kevin mentioned above was going to work for me after wrestling with it for an hour. It took a solid 15 minutes with the slide hammer to eventually get it out, huge p.i.t.a!
Old Jun 8, 2009 | 05:21 PM
jonesy's Avatar
grease and rod works great
Old Jun 8, 2009 | 08:22 PM
grimjeeper73's Avatar
wet toilet paper and something that just fits in the hole i did this on mine and it came out like butter keep stuffing wet toilet paper in and hammer away
Old Jun 10, 2009 | 12:11 PM
97FormulaWS-6's Avatar
Done both a slide hammer, and the toilet-paper trick. Both work.
Boss002
Jan 20, 2016 12:17 PM
realistyc
Jul 28, 2015 07:32 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
