How restrictive is my flowmaster with D1SC
Old May 28, 2009 | 04:48 PM
leebaker1973's Avatar
I have a flowmaster cat back exhaust on my lt1. I believe it is an 80 series muffler. The car has a 396, D1SC, AFR 210 heads with 1 3/4 long tubes. Is this cat back not letting the engine breath? Thanks Lee
Old May 28, 2009 | 04:50 PM
jsetzer's Avatar
I think there are far better options. Will taking it off make 100hp? Probably not. Turbos are much pickier about mufflers than the super charger.
That being said thats a large motor with extra air coming down the pipes. I would def look from something bigger, or dual cutouts close to the collectors.
Old May 28, 2009 | 04:55 PM
How about a single 3" cut out ? Thanks Lee
Old May 28, 2009 | 04:57 PM
I'll look at the car tonight. Maybe I'll put dual 3" electric cut outs. Thanks Lee
jsetzer's Avatar
Try it and see. What kind of power are you making/hoping for?
Old May 28, 2009 | 07:46 PM
The car made 496 at 4700rpm. But after 4700rpm, it had spark blow out. I now have installed a MSD box and bryan from PCMforless is going to re dyno it. I did this combo years ago and I only have 8:1 compression. At 4700rpm it had 12 pounds of boost. I think it may make 550hp. Thanks Lee
Old May 28, 2009 | 07:49 PM
After this dyno session, I would like to put new pulleys to get more boost. What do you think? What kind of hp do you think I can get out of this? Thanks Lee
Old May 28, 2009 | 11:28 PM
jsetzer's Avatar
I think you will run out of blower before you max the potential of your motor and heads.
Old May 29, 2009 | 07:01 AM
seawolf06's Avatar
Since the flowmasters are worse than the stock exhaust, I'd say yes, they are restrictive.
Old May 29, 2009 | 07:46 AM
4SFEDZ's Avatar
yes very restrictive! put a cut out on and tune with the cut out open and will prolly see 50hp, a buddy of mine gained 6xrwhp with a d1sc but he is in the 650-700 range
Old May 30, 2009 | 08:37 AM
97s10ondubs's Avatar
I picked up 29rwhp n/a when I had a flowmaster, just by opening the cutout.
Old May 30, 2009 | 11:57 AM
4SFEDZ's Avatar
being blowen and a higher hp application it will pick up more!
Old May 30, 2009 | 02:42 PM
Thanks guys!!!!! Lee
Old May 31, 2009 | 10:55 AM
streetbad's Avatar
Cool
Did your buddy have a single intermediate pipe? If so what diameter?. Was it one cut out or 2?
Old May 31, 2009 | 01:23 PM
4SFEDZ's Avatar
ya he is running slp long tubes into a y then 3" to flowmaster. added one cutout b4 the flowmaster
