screw on amp turned black
Old Jul 31, 2002 | 03:01 AM
zman0069's Avatar
Post screw on amp turned black
well noticed my sub stopped workin for some reason, i went and looked at my connections and the power wire to the amp came off, and i also noticed the screw/the area around it, is all black as if it was burnt, can ne1 explain this?? my amp doesnt even have the gains set at half so im assuming its not that.
Old Jul 31, 2002 | 11:45 PM
pseudoz's Avatar
Post
What amp/subs are you running. What was the gauge of the power ground and speaker wires? Did you use an inline fuse on the power wire and if so what size?
These answers will help us answer.
Old Aug 1, 2002 | 11:54 AM
zman0069's Avatar
Post
ok well heres what i do know, the install was done by a local audio shop, and they were trying to impress me becuz its the first ive had nething done there and they wanted to keep my business (i know this). anyways, the ground wire is fairly small, id say no more than 14awg. and the powerwire is run to a cap first then the amp, no inline fuse that i know of, except its wired to the fuse box in the front, its a Usacoustics 300 watt amp, and a jl 10w0-4, has been workin perfect for bout a year now. never problems with the amp at least. the screw no longer even turns, and is getting blacker......
Old Aug 2, 2002 | 02:09 AM
pseudoz's Avatar
Post
I would use 8 or 10 awg wire for power and GROUND. It is correct to have the fuse with in 18 inches of the battery. I would take it back to the shop and show them the problem.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
meissen
Jun 1, 2015 07:59 AM
Krab
Aug 5, 2002 12:08 AM
