relocating battery to the spare tire well
PaulN64
01-13-2003, 01:21 AM
who has relocated their battery to the back of the car and what do I need to do it? Also, any kits which will have everything that I will need?
stik6shift98
01-13-2003, 02:52 AM
just some wire.......i havnt done it.....but it seems preety simple
connect wire to the positve cable that would normally go to battery and run it to back of car
LS1 RULZ
01-13-2003, 07:24 AM
Just make sure that the battery you use doesn't vent gas when it is being charged. Otherwise you'll need to have a way for the gas to be vented out of the car. This is one case where I CAN recommend an Optima battery. They use a differenrt construction from your normal automotive battery and don't discharge any gas.
PaulN64
01-13-2003, 07:57 AM
I'm using an Optima Yellow top.
megabass
01-13-2003, 12:28 PM
Good move. :cool:
I would also add that you should try to secure the battery. What I would do is make a carpeted board to go in the bottom of the spare tire area and make some brackets to bolt it to the antenna brace. Then you can set the battery on top and fasten it to the board. This would prevent the battery from rolling all around if you take a corner hard. JMO.:D Good luck:D
Grover
01-13-2003, 12:48 PM
If you plan on doing any drag racing you will need an external shut off with a rod that goes to the outside of the car. It needs to be a "push to off" type of setup. Search in either the drag racing forum or LT-1 Tech this has been discussed recently.
PaulN64
01-13-2003, 01:08 PM
why would I need one? Is that a track safety requirement?
x7x7
01-13-2003, 03:21 PM
yes
Grover
01-13-2003, 03:24 PM
Yes, it is a NHRA & IHRA rule along with having the battery in a sealed box that is vented to the outside because our cars don't have a rear firewall.
Here (http://web.camaross.com/forums/showthread.php?s=&threadid=42709&highlight=battery+relocation) is a link discussing this topic.
PaulN64
01-13-2003, 03:28 PM
even with an Optima Yellow Top. That's what I'm using right now and thats' what I was going to relocated to the back
Grover
01-13-2003, 04:57 PM
Technically I don't know if the Optima batteries are SFI approved where they wouldn't have to be put in the sealed box. I tried contacting Optima directly but never heard from them, but if you don't do a lot of drag racing or if your track isn't that strict then you should be okay.
