Will the 6.5 Componets POLK MOMO's fit in our cars?
chesee48
01-13-2003, 12:50 AM
wasnt sure if they work or not? i want to know if anyone knows that this particular brand will work for sure, not by just seeing the size, cause i've never heard anyone using this..
thanks guys
chesee48@aol.com
Austin96Formula
01-16-2003, 04:23 PM
Yes. I put a set in a friends Trans Am a little while ago. You cant use the stock plastic mounting piece but what we did was trace out that plastic piece onto 1/4" MDF, cut it out, made the correct notch's in it and drilled out the wood in the same places the stock plastic piece mounted to and put it in. You will want to get some weather stripping or whatnot to help seal the MDF around the door (not like it matters to much with all the holes in the door itself). And they sound good.
chesee48
01-17-2003, 12:11 AM
sweet thanks!
Austin96Formula
01-17-2003, 01:14 AM
I might add, damn! those are some built 6.5".. I didn't think they would fit in the door either, those things have a huge magnet structure on them, and sound good also.
chesee48
01-17-2003, 01:33 AM
sweet, did polk come out with a newer component set or just thhe older version momo one? hmm i think i saw the new one at crutch hmm
