OneBadRedz28
04-27-2009, 09:41 PM
hey i am smelling fuel by my driver side rear tire. Is there any lines etc that are by there. Thanks
fuel smellOneBadRedz28 04-27-2009, 09:41 PM hey i am smelling fuel by my driver side rear tire. Is there any lines etc that are by there. Thanks ImNraged 04-27-2009, 09:44 PM The fuel lines run directly by that area. You fuel filter is there too. OneBadRedz28 04-27-2009, 09:48 PM hey thanks im thinkin its a bad line because i can smell it not much but its there even when the car is parked. DeuceGI 04-27-2009, 09:51 PM A stronger possibility is the charcoal canister for the Evap emission system which is behind a closeout panel in the back of DS rear wheel well. This is a fairly common issue and pretty easy to access. HTH OneBadRedz28 04-30-2009, 04:37 PM hey thanks man, does anyone have a pic of where the door is for the charcoal canister? DeuceGI 04-30-2009, 09:17 PM There's some info from 'da man Shoebox: .http://www.shbox.com/1/evap_system.jpg A fantastic site if you haven't seen it yet. HTH Injuneer 04-30-2009, 11:21 PM There's no "door" for the canister. You jack up the drivers side rear, remove the rear wheel, and there is a plastic panel in the fender liner held on by screws. Can't miss it - everything else is metal. A common cause of the problem is rotted rubber lines between the tank and the canister. Problem is, the lines are sandwiched between the tank and the body, making them hard to access. You may also have liquid fuel in the canister, from over-filling the tank. Or, your EVAP purge system (solenoid on the passenger side of the intake manifold) may be plugged with carbon particles and not purging the fuel vapor from the canister. | ||
