95 Z wheel wear/alignment ?
Old Apr 25, 2009 | 01:25 PM
Camm95Z28's Avatar
Hello all, I went to have my 95 Z inspected and it failed cause of excessive wear on the inside 2" of my right front tire.It has 198K on it and I have never had any alignment or tire wear issues til now.
My question is could this be just a simple " needs a alignment and camber" or maybe something else like tie rod,control arm, spring problem?? Thanks in advanced.
Old May 3, 2009 | 01:49 PM
Z28Freak86's Avatar
Sounds like you have a loose ball joint on that side. Either that, or the ball joint on that side is damn near its end. If its on the inside (toward the motor) of the tire, then thats the most likely cause.
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
