Amp question?
Old Jul 28, 2002 | 01:16 PM
MilkyClr69's Avatar
Post Amp question?
I just bought a Apline head unit. cda - 7893. Says it has 27 watts rms power x 4 with a 60 watt max. I have 2 blaupunkt 6x9's in the back with 75 w rms each. The two front speakers are alpine 4x6's with 25 w rms i believe. If I was to get two 5 and 1/4 inch speakers for the door panels, would it be necessary to get an amp for my system?
Old Jul 28, 2002 | 02:51 PM
LS1 RULZ's Avatar
Post
Only if you want to use all 6 speakers. If you intend to replace the 4x6's with the 5.25's then no, you won't need an amp. If you try connecting the 5.25's in parallel with the 4x6's you'll end up with a 2ohm load and I haven't seen an HU yet than can power a 2ohm load.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
silvermansteve
Mar 4, 2015 05:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
