LS1 Torsen question
ralf
04-24-2009, 07:04 AM
Is it possible that LS1 Torsen I have in my 1996 Camaro starts to play games? On sharp bends especially in first gear only one wheel is spininng but when I made a test for straight line placing one wheel on asphalt and another on ground it works - two nice stripes - one on groundside another on road. Car has approx 400 HP at flywheel.
AL SS590 M6
04-24-2009, 07:12 AM
A Torsen is NOT a posi. It's a torque biasing differential. It has no clutches locking the axles together. It does it's best to try to send torque to the wheel that has less traction. And if you continue abusing it, it will fail.
ralf
04-24-2009, 07:51 AM
So you are saying that its behaviour is normal and I shouldnt worry?
ralf
04-28-2009, 07:07 AM
Anyone please? I need to understand is it normal behaviour of LS1 Torsen diff?
Wild Willy
04-28-2009, 07:29 AM
The Torsen is torque-biasing- you will get twice the power at the wheel that has traction as you get at the wheel with little traction- when you go around a tight corner, the inside wheel lifts and has very little traction- The outside wheel is loaded, but only going to get twice the power that the inside wheel is getting- which, being lightly loaded, isn't much-
On a level, flat launch, both wheels have about the same traction, and will get similar power- and, both will spin if too much torque is applied-
ralf
04-28-2009, 08:32 AM
So the bias ratio is 2:1?
Wild Willy
04-29-2009, 11:42 AM
On the standard Torsen, yes, 2:1- On some of the Heavy-duty models they have 3:1 or 4:1-
http://www.torsen.com/fsae/fsaefaqframes.htm
