1995 Pontiac Trans Am 383 Stroker
eternalcfh
04-23-2009, 02:28 PM
This Trans Am is Loaded and nearly done. Red Exterior/Black Interior. T-Tops. I have a folder of just about every reciept to go with the car&motor.
Motor is the original block fresh bore/hone/line hone .30 over with a Eagle 383Stroker kit.
Balanced,Dynoed @ 418Hp/458TQ
Kieth Black Pistons
Clevite bearings
Comp camshaft
42Lbs Injectors
1.5 Aluminum Roller Rockers
Roller Lifters
Melling Hi Volume Oil Pump
Accel Distributor
Comp Pushrods
New Gaskets
New Water Pump
Hi Flow Fuel Pump
Suspension-
QA1 Shocks Front Coil Over
QA1 Shocks Rear Single Adjustable
LS1 Dual Piston Brake Conversion
Baer Eradi-Speed Drilled/Slotted 2-Piece Front Rotors
Baer Eradi-Speed Drilled 1-Piece Rear Rotors
BMR Lower Control Arms
BMR Adjustable Panhard Rods
Energy Suspension Bushings
Energy Suspension Stabilizer Bar Linkage Front/Rear
Flowmaster Exhaust w/ Slant Stainless Steel Tips
Beefed Up 10 Bolt Rear end W/ Richmond 3.73 Gears
Custom Built Transmission w/ B&M Shift Kit
Body/Interior-
95% Rust Free Garage Kept
All Black Leather
Non Smoker car
New Window Motors
Almost everything is new on the car. I planned to do a full Rest-Mod
but I have other projects and need money for school as well. I will sell the car as a rolling chassis $4500obo. Many other parts. Too Much to list.
For complete car Asking $7,700 obo Must Go! E-Mail Mike cfhbdbd@yahoo.com
